iPhone16/Plus/Pro/Pro Max Accessories Thread
galvin
fyi for those looking at camera button.. easily get scratch whether or not it is from apple or other brands
Same Taiwan Youtuber video as someone posted earlier promoting their own Taiwan cases.
Am using the Spigen camera control covered T cases and its a soft rubbery material inside. I had the Apple Silicone and Otterbox Lumen before also and i remeber it was a soft rubbery material on the inside of the button too.
Kyubi
yes but he did also mentioned all cases should have the same issue... may be you use more then you update us ? hehe
galvin
I use and swap often between my 2 Spigen cases. Doesnt scratch leh. Rubber/silicone how to scratch sapphire glass? If its the Supcase one scratching because of its metal needles inside, that i can believe.
Charlie_Zhan
recently got this SP quite popular on XHS.. alot of ip16 users in china say it doesnt block the screen. the brand is Turdi/图兰迪 if anyone is curious and wants to try buying on TB.
iosnewbie
Most user reviews say the black border is very thin. I found a couple of pics showing the SP before applying.
VodkaPear
Smartdevil vs Zigg
Boiijek
Does Zagg from Challenger carry any local warranty for replacement? Anyone gotten their zagg glass replaced before?
stanlawj
looks scary, basically otterbox, supcase, beats, apple clear case all can cause scratches according to the reviewer
only the 2 local TW brands can buy
on a side note, the chinese name for supcase beetle quite cute (literally jia3 cong2)
There is no evidence presented of scratches on the camera control button. The reviewer could be unscrupulous.
Sapphire-coating on the camera control button starts scratching at 5 and above.
Steel hardness is 4.5.
Hence safe to say, that steel/metal won't be able to scratch the camera control button.
ChaosPaladin
any good magsafe wallet that can be used with access card directly? i want to use with my condo access card without the need to take the card out of the wallet. Best is if it can have a stand as well, like MOFT.
kuang89
Anyone got the new Spigen tough armour T case?
feeling nostalgia ordered from Amazon for $65
jianrong
I order online. It deliver with Airpaz shipping. it only send a message saying delivery team will get in touch with me.
