IPPT, IPT & RT Questions...
stereobox
today is my phase 2 first ippt session. what's the earliest time i can book in?
if can't make it for the session, then how ah??
vasilli07
Does RT IPPT follow non-ict timing? If yes, then in-pro timing is 4.30pm to 5.30pm.
Maybe can do makeup lor.
aYu82
Hi, may i know if there are such a thing as fail IPPT first time and may be exempted from RT?
vasilli07
No...unless you are medically excused for 9 months and above, then you will be excused RT.
If you think you are going to fail your IPPT and going for RT, choose IPT instead. It's shorter than RT.
lil_paradox
Hi ppl, I'm wondering which camp is better to attempt my IPPT in terms of passing rate and level of difficulty coz from what I heard, there's a running track at khatib while Maju conducts the 2.4 at the carpark. Does anyone knows what time the morning session usually commences/ends?
One more thing, what's the proper attire to be worn when walking in to the camp/during IPPT. It's my first time going for IPPT thus have no idea. Am thinking of booking the test next week. Need some advice. :)
vasilli07
If you are used to running in the stadium track, then Khatib is the place to go. Not too sure about Maju.
You can just wear your PT attire there.
aYu82
Is there a way to talk to FCC or my unit? Becos its my first attempt and my window closed =/
stereobox
if i missed the ippt test, do i still need to book for another non-ict ippt after RT, or is it considered i already did one for the workyear?
vasilli07
The faq for the new IPT is updated on ns.com liao. For people who still don't understand the new system, can read it there.
IPT participants who are injured will still be covered by SAF...thought they said no coverage. :s7:
SAF's Provision for Injury Compensation
NSman who volunteer for IPT would be covered/compensated in line with current SAF provisions for any injuries sustained during IPT session. The NSman must be registered for the IPT session prior to the start of the session so that the NSman training commitments can be verified should the NSman makes any claim for compensation.
stone11
It's like that as your new window is open. Even after taking IPT(if you fail your IPT IPPT), they will still ask you to book your IPPT as you have yet to pass. It's the system standard procedure.
You can try booking your IPT to see if you can do it.
hi vasilli07, i booked my ippt with the follow message after i have booked
'Note: This is your 8th IPT session and if you fail to attend, you will not be exempted from RT in the following IPPT window.'
vasilli07
Just telling you that you need to attempt this IPPT after 7 IPT sessions to complete IPT.
skyElevan
If i missed 1 RT session in Phase 1 on weekends. Make Up on another weekend, yet did not attend. Will i face any charges? Can just skip that 1 lesson??
vasilli07
Depends on your unit. If they are strict, they will charge you even for missing 1 lesson.
TiOnGSquare
sry..ask u all, today i took my ippt and failed one static station so i plan to take tat station every wk until i pass..just wondering when will they allow me to book another ippt/update current ippt results in? cos i wan to clear it before my window closes..busy later riao..
vasilli07
You can take the static station only but I not sure how many times they allow you to book. You may want to check with the FCC.
Your IPPT results should be updated 1 or 2 days after you taken it.
