IPPT, IPT & RT Questions...
vasilli07
thanks bro!
btw just one more question, does NS.SG have the PPT chart anot? I just can't seem to find the chart to check my X weight loss requirement. Anyone can provide the link? thanks :s12:
Need some help here,
I ord last year so i currently have 12 mth to clear my ippt.
Let say if i fail my ippt for this window.
do i still have 3 mths to clear my rt-ippt?
am i still eligible for IPT?
Yes, I believe you are eligible for the 1 time conversion from RT to IPT. Call ns.sg to double confirm.
hi guys, i just completed my first session and they say my band is band 2.. so do i have to clear all the stations in band 2? or just select 1? i can clear all except running now...
All stations must be the same band, so yes, band 2 for running too.
merrr111
new window = must do ipt-ippt again in order to get new ppt.
and your ppt increases every year.
thanx bro...
vasilli07, can help me double confirm?...if it is, next week i go book a ipt-ippt to get the new ppt for this year's window...:o
vasilli07
Your ppt will just +1 each year. IPT-IPPT cat test result only applicable if u don't have any past IPPT result.
merrr111
hmm so means i just book a normal ippt n if i can meet band 2 from my previous band 1 last year, i will be cleared for this year?...:s11:
vasilli07
No, u still have to book ipt 1st. Go for cat test then get band 2. Book another ippt session to clear.
Elspeth
vasili kor kor if take ippt during annual ict and meet ppt target 1 will counted towards meeting target and clearing for that yr ippt req?
kurenai
I attended 1 IPT session then attempt another IPPT session and was able to clock band 1 as per required.
However after the 9 months window, mindef still tell me i need to complete my 20 RT sessions.
May i know wat i missed?
vasilli07
Your ns portal status got state 'completed ipt with ppt met'?
kurenai
You have FAILED your IPPT for the period 29/11/2011 to 28/08/2012.
You have NOT COMPLETE your IPT for the period 29/11/2011 to 28/08/2012.
You have NOT TAKEN your RT for the period 29/08/2012 to 28/11/2012.
Your next IPPT window will start from 29/11/2012 onwards.
I never attend e full 10 IPT session
vasilli07
Check if your latest IPPT result is in your ns portal. Check every station is ppt 1 standard. If yes, call ns.sg. Maybe system problem.
It's ok, u can clear IPT in 2 sessions.
mep123
need some help on ipt/ippt.. I have defaulted ippt before but never get charged. Subsequently I atttended the rt and finished it.. But this year round I opted for ipt instead of rt.. Caused defaulted ippt again.and defaulted the ipt also is it unit forget to charge??. If get charged considered 1st time or second time since never answer charge b4
Raider04
Never been charged mean never been charged. Anyway IPT is voluntary, how to charge.
Elspeth
if attempt ict ippt and meet ppt band 1 standard consider clear for yr rite? then i've remaining 3 ipt session. 7/10 ipt session attended. still need to finish attending the remaining 3 session?
Elspeth
also if i dun meet standard... but after say 1st out of 10 session rt i meet ppt band 1 standard if i bk my own ippt, still need to attend remaining rt sessions?
vasilli07
Don't need. Please wait a week or so and check if your status changed to completed IPT with PPT met.
U can't book IPPT during RT period. So earliest u can take is on the 8th session, which also is the last session. :s22:
