IPPT, IPT & RT Questions...
Elspeth
Don't need. Please wait a week or so and check if your status changed to completed IPT with PPT met.
U can't book IPPT during RT period. So earliest u can take is on the 8th session, which also is the last session. :s22:
i tot is 10 sessions
otaku7
hi all,
questions for getting excuse on rt how?
i don't really see ns portal got any number.
i actually booked rt a few weeks back. but injured myself. and now i'm in hospital for surgery and will only be discharged 1-2 weeks later. and my window for rt is closing in 2 months time...
i also doubt i would be fit enough to attend then too.
coz i tore my ACL...its gonna take a few months minimum for rehab etc.
vasilli07
hi all,
Call ns.sg then they will contact your unit for u.
ZeroCube
hi,
I apologise if the questions have been asked before:
1) Assume that i did not complete IPT (attend < 10 sessions), and PPT was not met. When i go for my 20 sessions RT, will i need to pass my allocated PPT band or do i have to pass the standard IPPT?
2) If my birthday is on 31st Dec, i assume my window closes on 30th Sept. Can i still take my last IPT lesson on 30th Sept?
Thanks !
vasilli07
hi,
Thanks !
1) I don't think so. You may want to call ns.sg to double confirm on this.
2) If u can book, then can lor.
fwl18
hihi, have searched around to look for the IPT scoreboard without success, may i know where can i find it?
I failed my IPPT last window and is eligible for to replace RT with IPT as it's my first IPPT after i ORD, will they take my last results to determine my bank or do i have to do the CAT test?
Thanks alot for ur time!
LiNuxIDIoT
for the current rt, if i booked and cant make it and cannot cancel after 12pm. if nvr go will have any penalty?
vasilli07
Check the ipt faqs, found under the drop down menu after u logged in.
Most likely yes but still try to do your worst in cat test if u cannot pass.
leonardo83
Just some info. For those that passed their IPPT in their previous window and wish to enrol in IPT for the present window, you will get PPT 3 even if you get 0 for all the stations in the cat test.
vasilli07
Cat test result will not be used to determine your ppt if u have a past ippt result from last year.
vasilli07
Just to confirm for u now...
Determination of PPT
The PPT standard for the NSmen in a typical birthday window will be derived from the first IPPT test result conducted during the 1st session of the IPT. Test results from the 1st session will be compared with the previous year, and the results with the higher IPPT standard will be used. For NSmen who just transited to ORNS, the 1st session IPPT result in IPT will be used instead. The entry level of the lowest performing IPPT station will be used as the starting point to derive the target PPT standard for all stations. NSmen must achieve the next higher level by the 10th session (IPT IPPT) in order to be considered as having met their PPTs. See Table 1 below for illustration of PPT starting points.
pakthedude
Once login, go to IPPT Menu, on the dropdown Menu, select General Infomation, scroll down to select "IPPT Preparatory Training"
AhzOnG
hey guys, got a big prob here :(
I havent complete my RT/IPPT yet and my birthday in this month..I got the letter to go report to CMPB..
anyone know what kind of consequence I might kena? and if Im still not able to complete my 20sessions RT within my last window?
Raider04
A Fine and 20 Sessions of RT!
