IPPT, IPT & RT Questions...
linkiat
Hi all,
I know in the old system, you are allowed to skip 2x RT Sessions in phase 1 and 3x RT Sessions in phase 2. So ttl attend 15 RT sessions and you are considered to have cleared your RT requirement.
what about under the new system? do you have to clear all 20x? I'm guessing official statement is yes but has anyone hear cleared < 20 and still consider completed RT?
vasilli07
Hi all,
U now book every single session yourself and with that they have closed the loophole.
And if u didn't complete, your ns portal will be stuck at 'have not completed' rt.
j_t_fusion
Hi all,
must clear all 20 sessions... no less.
sessions that you booked but did not go will not be counted.
mynickname
Bros, went for my last RT (no. 20) last week and passed with incentive. How come no SMS on when payment of RT attendance and incentive ah?
Bak_Chor_Mee
hi vasilli07. i will be attending my very first IPT session today. just wanna check, i understand the very first session is an IPT-IPPT session to determine which band i am, so when i book an external IPPT, my results just have to meet the mark of my band right? please advise. thanks. cause my most jialat station is 2.4.. hoping to have some "time extension to the 12min 40sec".
vasilli07
Would suggest u wait a week or 2. If no update, call ns.sg to check.
vasilli07
Yes, u will have to meet the band in every station.
Bak_Chor_Mee
Hi bro the PPT 1 2 3 and 4 is the band level? Or isit thr meeting requirement for each year? For example this year im taking my IPT so is no. 1, next year no. 2 and so on?
vasilli07
Yes. No matter u pass or fail, your ppt will be +1 every year.
chansl89
Hi
I just finish my IPT test at Safra .. My target is band is 1 .. When i check, it reflected fail in my ippt past score .. But when i check IPPT Prep Trg attendance .. It reflected as Complete with PPT Met .. So does it mean i pass my IPT and dont need to go for training liao ? Appreciate some help as I am very new to this .. Thank ..BTW i did hit the band 1 target during my Safra IPT test ..
j_t_fusion
Hi
technically, you still failed your ippt but since you met your target band, you are considered to have cleared your ippt commitment for your current year.
so no need to go for any more ipt, ippt, rt for the remainder of your current year.
chansl89
Thank for your quick reply
1) So i assume i can cancel all my booking of IPT slot?
2) My score said i best achieved band 3, so does this mean next year my target is band 3 or just band 2?
j_t_fusion
next year will be target band 4...
chansl89
Crap to the max .. Why did i try so hard .. Any way how to drop it back to 2?
If next year window open, can i go take IPT and fail again then take the target band .. or i die die must pass my IPPT ?
chansl89
Ipt cat test result will only be used if u do not have any past ippt result.
Hi Bro
So do i consider to have an ippt test result ? Afterall i still fail and get my band 3 .. So is it confirm next year die die must get band 4 or can i fail my ipt again and try band 2 ? Thank you
