IPPT, IPT & RT Questions...
Pryson
For the target band 1 for PPT standard, i must meet all of the 5 stations? or specific station? TIA
odadda
if tio charge for defaulting and the trial dates clash with dates that i planning to go overseas, can request for change of dates? thanks in advance.
vasilli07
usually how long will it take for the letter to come? as in from the day my window close till i report to cmpb?
Should be within a month or 2, answer charge should also be the same. A weekday noon time.
synergyoff
hi, like to ask, how do i extend my RT for one more month?
when (time and day/date) and who (name) should I approach to for Bedok FCC.
how do we know when will they be around?
approach the OC or 2IC of RT's FCC?
vasilli07
I believe you can just approach the PTI or admin staff before or after your training. They should be free by then.
BlackCube
walk into the fcc room on level one beside the gym, opposite the pull up bar.
ask anyone, then will give u form to fill up.
BlackCube
anyway, just want to check about ipt band thingy.
i understand there's few band right, about 4 or 5?
so each year u need to pass each band to pass that year ippt.
so if i take normal ippt for first 5 year, on 6th year then i go for ipt.
am i consider for 1st band?
vasilli07
Your last IPPT result will be taken into consideration to determine your ppt. So if u have pass your last IPPT, you won't get the lowest band. Maybe a band 3 or even 4.
Xylitol
ipt has 4 bands, and when u enrol into the ipt program, u will take a ippt "cat" test on the 1st session, ur banding will be determine by the system based on ur past ippt results and ur 1st day ippt "cat" test.
d3bugu
quick question, what will happen if we didn't complete 20 sessions of RT or totally not go at all.
juventusfc27
for not attending RT at all, it's either u pay a fine or get charged if i remember correctly. the higher ur rank, the heavier the fine. if u keep doing the same thing, be prepared to go DB.
CLEAR WINDOW LIAO UNTIL MID-2013! :D
vasilli07 korkor ur display pic is who? =:p
kirara86
what will happen if i cant complete my IPT on time? my deadline is end of this year.... same thing? fine $50??
juventusfc27
IPT only applicable for first 9 months after ur bday. if u cant complete or meet the PPT banding requirement by IPT deadline, u have to go for RT liao in the last 3 months of ur window.
kirara86
forgot to mention i am from SPF...
i think the procedure might be alittle different from SAF. SPF follow FY instead of bday.
what i can see in ns.sg... they want me complete 9 session of IPT and 1 ippt by 31st dec.
and earlier this year they did send letter for ippt. but i didt attend. cuz i book ipt already.
so i guess if i cannot finish IPT by 31st dec.. it will make me defaulter straight..
gotta say SPF/SCDF IPPT system is still dam screw up... call their department they oso cant answer our question and taichi here and there.
