IPPT, IPT & RT Questions...
siandiaola
quick question here, if i did IPT previous year and acheived band 1, this year went to do 1 session of IPPT(i did not register for IPT this year cos i forgot about it) and failed so end up in RT.
So now in RT, to get out of RT do i need to pass normal standard or achieve band 2 for IPT standards can already?
and also, if RT starts at 6pm, what is the latest time that they will still allow me to in pro?
kazuki666
Few questions. Was the ippt ipt de? when was your 1st session rt, and when is your window closing? I am worried you may be charged for not completely ipt. I got this blur charge last year too...
You better call you up ns hotline to confirm.
vasilli07
No. As you didn't sign up and complete IPT this year, you won't be eligible to use band 2 although the band automatically is +1 every year. You will need to pass the normal standard if you want to get out of RT.
Should be around 6.20pm.
vasilli07
An individual won't be charged for not completing IPT unless you used the 1 time option of converting your RT to IPT and then didn't complete it. RT is supposed to be a punishment, converting it to IPT doesn't mean that it becomes a voluntary training.
kazuki666
Me and a bunch of other ns men were "threatened" to be charged last year at the cmpb. Then we were really unhappy how the system didnt work correctly.
What I did was attended IPPT (didn't know it was IPT IPPT) 2mths after my window opened, failed. Then waited till 2mths before my window close, then started doing RT. Booked 20 sessions le and attended like 15 liaoz, was called back to cmpb.
The officer there warned us that if we take IPT IPPT and fail, die die must attend finish the IPT, else confirm will charge. Really dunno how the system works sia, I am merely quoting their words...
vasilli07
Like I told u before, u opt for the 1 time conversation from RT to IPT. For your case, IPT is compulsory since it's a punishment. Your RT that u did is for that current year, so u actually skip a year of RT(which u converted to IPT), that's the reason u are charged.
siandiaola
thanks for the prompt reply bro. is there anyway i could "convert" back to IPT standards for getting out of RT?
vasilli07
U will need to clear your RT or pass your RT IPPT 1st to get out of RT for now. After that when your new window open again, u will have to register for IPT again if u want to get a band.
Rusty89
Wa sian. rain whole day how to go for IPT later? :(
What will happen on rainy days ar?
fluegas
If last yr pass 2.4km (12.35min), this yr fail (13.59min) and i intend to sign up for my 1st time IPT. Which band do i fall into for Cat Y1? Is it determined only on the 1st session in IPT or it will be based on previous IPPT results as well?
vasilli07
Last year result will be taken into considerations too.
chopra
I think this definitely had been asked before. Can someone tell me what's the latest time to reach MAJU camp for ippt?
PSP1_Geek
Telephone number of Kranji FCC
Hi,
Any1 here tried to call this FCC and managed to manually book a same day slot via telephone? I intend to bk my IPT for today. Missed the timing to book it:( but don't think that it is filled.
Anyways, it would be my 1st IPT session, thus I'm expecting an IPPT to go along with it. Do they conduct IPT-IPPT on Mondays?
Thanks in advance!
vasilli07
Hi,
Thanks in advance!
This FCC is which FCC? Doubt u can book via phone for the same day.
No ippt of any sorts on Mon.
