IPPT, IPT & RT Questions...
That's not true. If it's more than 30 mins, you will most likely be asked to come another time. If not, everyone will come at otot.
That's an unofficial rule. If your unit is strict, they can charge you for missing just 1 rt session.
i quite fortunate liao, cuz phrase 1 missed 1 rt but din do mut; don really wanna take leave just to take ippt, n if after work go, the number sure go 4xx:s27:
Ironfisto
1) first session usually waste ur time for 1 hr to queue up to take ur weight n height. they will brief u abt the rt... what u have to do.. what u can do what u cant do.. blah blah blah
2)come late for rt can still in pro.. u come at 7 oso can still in pro. just that u will be release later... ie if u late 30 min, u will end 30 min later den others. if u late 1 hr, u might b released 1 hr later den others
oh kk thx.
wiLLy_LucifeR
hi guys,
i wanna clarify if i get a pass during a partial failure retest during my rt-ippt, does that count towards my current window as well? or is it tt i'm only released from RT n i still need to book another IPPT b4 my window closes?
thanks all.
ragnarok95
Senior Moderator
Senior Moderator
Same as me...goign tomorrow to khatib camp for IPPT @ 730...but the diff is that...im going there to fail. :s13:
Anyone knows now if the 2.4KM need to complete all 6 rounds or just run one round and can fall out liao?
Last yr i was here it was 6 rounds die die...even the PTI also KPKB say stupid rule...haha
anyhowsaysay
die die must do 6 rounds :(
othniel80
in phrase 2 one can miss 3 times; can i use 2 of the 3 'misses' for ippt??
you can but it makes no sense unless you already have one recorded attempt during your RT. else you will have to book and attempt one ippt after your RT ended when your window is opened.
toonus88
i booked my IPT, attended 3 lessons. just got my MR letter. I can safely skip the remaining IPT right?
Swordsman
sorry if this has been asked before. if i clear my ipt that means my current window is clear, do i still have to take ippt during ICT ?
ragnarok95
Senior Moderator
Senior Moderator
Ok for those who are wondering if you fail other static station, 2.4KM do you have to die die run full 6 rounds?
Just came back and the answer is NO. They changed the rule again. It's back to the old one whereby you can fall out just after one round instead of die die must run 6 rounds rule. ;)
lonestar86
i went ns.sg to check if the system has capture my ippt results, but it says,"You have not participated in any IPPT." the update is not real time meh?
vasilli07
yes...as ICT IPPT is part of the training programme. You can fail if you want, they just want your attendance.
yeapa11
hi..
who has taken RT at bedok b4?
miss RT must have MC de isit?
or can just do MUT??
the RT at bedok xiong??
