ctstalin
- Mar 22, 2007
The answer is NO !
What if during the ICT the unit conducts its own ippt test? will it be counted as taken?
The answer is NO !
if my window closes already, n i took my IPPT n failed, I mus take my RT by when huh?
thanks thanks
Hi guys, i will have my first RT session later on at bedok camp. Got a couple of qns.
1) wear what ?
2) it's from 4-8pm , 4 fricking hours, may i know what do we do there ? Dont tell me train for the whole 4 hours ? And got end earlier one anot ? Like 5+ 6+ ?
hey me too! lol.
1) wear pt kit loh. compulsory singlet or not, i'm not sure.
2) heard its around 2 hrs plus only, the rest of the time is admin stuff, etc.
1) wear what ?
anyway to zhao earlier ?
hi guys, i will be having my 1st RT later on maju camp, can i know what to expect there? n is there locker for the cam phone?
basket ball shorts and tshirt is ok right?
thank you
Try to avoid bringing in cam phone. If you die die must bring, there is row of lockers outside the guardhouse. Deposit your phone there. Bad thing is need 20c.
Try to go early so you can get a tag number. The counter close 4.30pm for RT men.
You will start off with some light warm up. Since this is 1st session, there might or might not be short briefing session.
Then do some basic set of exercise lor. Pushups, crunches,.....
Then go for run. By 6pm, you should be outside the camp liao.
1st session usually not so siong de.
Your attire should be ok. Your T-shirt must be collarless. Avoid polo.
thanks for the reply, another thing is , do i put my wallet into the locker also or there is some place inside the camp to put the belonging?
ehh how come my rt status is still ongoing when my last rt session is on sept 4(though i din go for the last one n absent only 2 RTs)??
