IPPT, IPT & RT Questions...
vasilli07
.笨 小 孩.;43682821 said:
if my IPT session starts on tue (02/02/2010) but now that they implement this flexible timing thing, so can i go on monday? or first session must be on tue no matter what?
just go to ns.com and check...your schedule should be changed to mon and tues liao...mine already changed despite selecting mon and wed...
.笨 小 孩.
my initially choice is on tue and thur. now they change it to mon and tue. but the start date is on 2nd feb which is on tue.
so my question is first lesson only can attend on tue? first session is trial ippt + briefing right? if i go on monday... wont i have to like join other group and miss out my trial ippt and briefing?
cbu
Is IPT like RT, can late up to 30min? ie 7.30pm for IPT?
vasilli07
30 mins? They may choose not to inpro you, so up to you to take the risk...15 mins should be the max time you are given...
KazeWashi
max allowance is 10-15 mins, after that you have to book another day to do a make-up unless on that day you are super lucky that there is some problem with their in-pro system then they will take quite long to in-pro maybe 20-30 mins and you can just join the queue.
vasilli07
For people who are attending on mon, they will also have the ippt and briefing as it's their 1st day, you won't miss out anything if you attend on mon...maybe on wed and onwards, you will miss out on the briefing as it's probably the mon people 2nd session...
cbu
still got ippt on 1st sesson ah? thought only briefing then can go home... :(
cbu
1st lesson and 8th lesson is ippt
actually it is more slack than normal lesson
i rem RT 1st session only got warm up and briefing then go home!
IPT got so much time ah???
Cause i got something impt tml morning, so cannot be tired.
so if got ippt, maybe thinking of Wednesday then start...
Kapish
NEW IPT SYSTEM Explained
-7 Trg+1 Test in 5 weeks
-No fixed schdule,Nsman can come anyday(Mon-Thurs,Sat PM)
-NSman are to book a Non-ICT IPPT for thier last session before the date printed on your outpro slip
and after your 7th session
-NSman must have 1 day rest in between(i.e Session must be on alternate days)
-Max 3 Session/week
-NSman will have to clear his RT in his current window,if any
so that means my schedule is currently mon/tue ... that means if i choose to go IPT on wednesday i can do so without informing right?
anyhowsaysay
ipt got brief then go for ippt lor
but u can dun take it seriously just go through the motion
vasilli07
should be able to...but you miss out on the briefing and maybe important stuff about the new ipt system so I advise you to go on 1st day...
cbu
1/2 walk/run 2.4 also quite tiring for me... :s22: think old liaoz.
Guess I try go tml evening in order not to miss the briefing bah.
Buaya_Hunter
ya lor...i actually book my schedule 2-3 months back when the change it not implemented yet...i booked mon and wed but now I checked, changed to mon and tues...just ignore the days, they give you 2 days as you need attend at least 2 per week if you want to finish in a month...
So it means that if possible, can chiong ipt on mon nite, thur nite and sat afternoon, rite?
