IPPT, IPT & RT Questions...
vasilli07
Pardon me for asking another noobish question. So, for the 8th ipt session, I could go for any ippt slot as it is after the 7th ipt session and within the 5 weeks from the first ipt session, rite?
Should be the case...just listen to the briefing they give on 1st session...
cbu
99% going tml evening @bedok...
Those going today evening, dun mind can provide some updates later?
thank you very much!!! :s12:
sneggg
oh so is complete within 5 weeks but go anyday u like? correct ?
cbu
Upz
did the PTI say anything? thanks
dante-z
-NSman are to book a Non-ICT IPPT for thier last session before the date printed on your outpro slip
and after your 7th session
When is the date usually ?
toLonG
Just attended yesterday's IPT at Khatib, damn sad, from now on, no more free MUT for block off..that means you die die must attend 8 session.
cbu
U sure? the Bedok PTI told us that Feb batch is the last batch to enjoy block off. so 5+1(6) session only. 3 cheers! 12-19 is the block off if i nv rem wrongly.
Kapish
just went maju IPT
confirm block off will get free 2 attendance .. hooray! :D:o
cbu
Making a contribution to answer some of the doubts. :s12:
Should be correct unless the bedok PTI bluff me.
This new program is called Flexi IPT. It starts now.
What posted previously is correct:
-7 Trg+1 Test in 5 weeks
*5+1 for the lucky Feb batch. Last batch. no more block off for future IPT
-No fixed schdule,Nsman can come anyday(Mon-Thurs,Sat PM)
*yes any day, including ur 1st day of the session. but declare to them if u did not do it on the 1st 2 days. note the 1 rest day thingy.
*note that this booked IPPT is of different timing. I dun rem wat time though, its earlier than normal training.
-NSman must have 1 day rest in between(i.e Session must be on alternate days)
*applies to everything.
-Max 3 Session/week
*due to the rest day
-NSman will have to clear his RT in his current window,if any
-U can switch any FCC anytime u like, no need tell them. Above rules apply.
-1st day is IPPT.
-the stupid improvement scheme is NOT implemented. At least not yet.. hopefully never.
Bedok FCC only extra notes:
-Training is going to be xiong. That PTI incharge of Bedok FCC IPT is darn on one. Last time he RT also do the most training and release the latest. so expect release timing close to 10.
-Cannot be late like RT. On the dot closure of in processing.
*SO if u wanna relax one corner type, DUN choose Bedok FCC. My home at Bedok so no choice...
vasilli07
you all so good...khatib not confirm yet...got to wait till thurs then can confirm...but likely to be same as bedok and maju...
anyhowsaysay
if u want can go to maju
last time i went is relatively slack..
even more slack than the RT somemore 1 hrs later than rt but release same timing
that time i went is conducted by reservist pti which change every week
vasilli07
This is like your normal non-ict ippt timing...4.30 to 5.30pm inpro...
cbu
Dun worry, since there is a free no limitation fcc switching, the benefits of the block off should be the same.
jim316
Wow, this is good news. i went maju mon, later will be going hopefully its true else really tight sia....
vasilli07
Then anyone going to clock 3 sessions this week? Then 2 next week...after CNY week, just go for IPPT...
