yea, i'm not into household chores, but my wife is appreciative that at least i keep the floor clean from dust and grime although by some non-conventional method. so she's happy and i'm happy cause i can let these robots do the work. it's like these robots are cheaper than hiring a maid, but the functionality also limited la. heh...
i think the plus point is, you can let it do the cleaning when you are out. and i think this should be the way, to be out of the robot's way. heh....
Don't think I can let my neato out of my sight when it is doing cleaning, if not might get stuck under the cabinets... or vacuum up the wire of my air purifier. But so far, the robot does a good job, can go under sofa to clean too, which my hand held vacuum cleaner cannot do so.
It may even start to look left and right before deciding on how to clean the area. Very smart fellow!!!
