Is having a front intake fan pointless ?
lonely5
I read that the front intake fan is meant to create a airflow to the rear but than the front to the rear is just too far to be effective so it does nothing just cooling ur hdd and nothing else liao .. Unless ur front fans are like 5000 rpms
Izzit true ??
Anyone got install front intake fan and really is pointless ?
jtjt00
No, use high static pressure fan for front intake fan to push air through hard disk area.
wuweiz
2x front air intake fans @1200 rpm blowing towards HDD, PSU n gfx.
Whole system quite cool compare to old system w/o front fans even when gaming.
Conclusion: they r not useless.
watzup_ken
Front fan brings cool air in, and the hot air should be exhausted out of the case by a rear fan. They are not useless from my opinion and experience. Depends on how you configure your fan to optimize airflow. ;)
noobiee
2 120mm intake fans to cool mainly my hdds
if not up lorry fast
cheongking888
Intake fan works better than Extracting fan.
The extracting fan may not be strong enough to create a negative pressure in the casing to allow sufficient fresh air (outside) to be drawn in via vent holes.
Hence, the intake fan mechanically draws in the air, cools the CPU etc and in turn it is pushed out by new fresh air through the vent holes.
If your casing has very small vent holes or they are located directly opposite the intake fans than the cooling may not be effective.
The vent hole (be it inlet or outlet) must be situated in such a way that it creates a "Cross Ventilation" in the casing.
hohohos
For me,
at least must have one intake 120mm fan and one exhaust 120mm fan:)
yewtee7
You want to create +ve air flow in your casing, meaning more intake than out going air. Else dust will be found in every hole/opening of your casing.
Just get those washable filters will do. Every few months wash them. Major cleaning of those fans/cooler inside your casing, once a year will do.
Coolman
basically u cnt have all intake fan cos all air in will block hot air from going out and will still b hot.
U blow a cool air in, if u blow in hot air, it will b hotter.
It really depend on how e whole configuration is to determine e best flow.
dun forget, fan is just a circulating of air, it is not cooling.
u feel cool bcos e 'wind' circulate away e hot air.
worst is casing fanless, air is still, and will b hottest.
Coolman
True, but how can the air outside your case be hotter than the air inside the case? :p
tis is not wat i meant, is just dat e sentence is not wrong.
give u an example, outside is hot, u on aircon in ur house, do u still on a wall fan dat suck in hot air from outside.
ragnarok95
Senior Moderator
Senior Moderator
Depend on casing design etc. Most work PCs i came across only have one exhaust fan and they still last for yrs.
Coolman
true, but most work pc is not hot, a gamer pc e graphic draw more power den processor.
ragnarok95
Senior Moderator
Senior Moderator
True. I believe HP server Z2XX/Z4XX also one single fan. My Servers are using one delta fan for 24/7 operation... :s13:
Arhhh.....Delta.. i miss them..
Gamer wise... i still prefer a min one in, one out.
Coolman
work place aircon 24hr on.
Ark Law
If work PC sit in A/C room throughout it's lifetime, of course will last much longer than if it were to be placed in my living room where my Phantom 410 easily collects a layer of dust after 1 month
tegeus-Cromis
Of course not, but that's because with the aircon on, the house is cooler than the outside. But the air inside your case is never going to be cooler than the air in your room. . . .
Not disagreeing with you when you say you need some exhaust, of course. But you are surely mistaken when you imply that 100% intake is worse than no fans at all.
Coolman
my post nvr say dat outside air is hotter den inside e casing, did u find any senetence in dat post, i was just talking about about physic, a very general statement.
