ITX Cases
hg2
Noob here and have not touched DIY rig for long time.
Mini-itx smallest form factor for DIY right?
Any recommended slim casing preferably with vertical orientation due to space limitation.
Onboard graphics, M.2 SSD will be fine and no wifi needed.
If budget permit, go with NZXT H1. You just need to plug and play! many video clips on utube showing how to install in 30minutes...
yusoffb01
if you dont need graphics card, stx is smaller. eg deskmini or intel nuc
XiaoFu99
Wow! Just checked and $569 only for casing and power supply. Chio, flexible with mini ITX, discrete graphics but expensive.
The width seems bigger than Asrock deskmini.
Thanks for the recommendation.
XiaoFu99
Looks decent, just to check, what's the maximum AMD processor it can support? I saw most of the review with 2200G or 2400G. Thanks for recommendation.
yusoffb01
kimsix
any comments of inwin a1+? it comes with 650w gold psu and 2x120mm fans and rgb. like really good value for $270
where to claim inwin warranty?
Force89
Hope they bring in the NR200 version that supports ATX PSU!
Sent from OnePlus GM1900 using GAGT
EmPtYsOuLz
The NR200 looks interesting!
Still waiting for H1 to restock but might get the NR200 if the H1 doesn't restock when the RTX3000 drops
flame2000
It's one of the better ITX case from those mainstream manufacturers.
*double post*
hellspawn_one
Read from reddit that Coolermaster should be including the ATX PSU mount at a later date.
But what will be sacrifice? The gpu size or length, or the aio compatibility?
Sent from Samsung SM-G970F using GAGT
hafiz116
Been looking at quite a number of ITX Cases, read about them too, just wanna know if there's any users here who would like to share their experience with them, building process, thermals etc.
This could also be of help, for those who are looking for ITX CASES, it's a list of the ITX cases that are readily available to get, prices ain't the cheapest, but I just get any prices I see online to get a rough gauge.
These are cases that I've looked into.
Below $200.
NZXT H200/H210 - $140
LIANLI TU150 -$160
PHANTEK EVOLVE SHIFT AIR - $169
INWIN A1 PLUS with 650W GOLD PSU -$279
RAIJINTEK OPHION - $179
Thermaltake V1 - $79
Cougar QBX - $70
Silverstone LD03 - $168
Silverstone RVZ03 - $170
Node 202 - $110
A50 M-ITX CASE - 69.90USD WITHOUT SHIPPING
These are just some of the cases I looked through but can rmb now on the spot, I'll update as time goes. Haha!
Just wanna know if there's any users here who would like to share their experience with them, building process, thermals etc. Did you regret getting them.
If you have any others to recommend, I'm all ears! Haha *below $200 budget pls*
DANCASE,ncase too expensive, but ya they are good haha!
Are you looking for just a case because you already have everything to go into the ITX already?
Preacher1010
my guess for the retail price of the CM NR200P here would be around SGD$150
Sent from The Bowels Of Purgatory using GAGT
