Kingston or Crucial?
enenyi
Don't get mix up. Single and double side memory doesn't determine whether it is single or dual channel.
Dual/single Channel is DIFFERENT, nothing to do with the physical attribute of the memory stick. It is determine by the motherboard itself.
So 4 barebone valueRAMs put together also can get quad-channel?
I got GSkill Ripjaws mainly for aesthetics, so unaffected by whether single or dual or quad.
ragnarok95
Senior Moderator
Senior Moderator
As long as same rams in the same color slot will give u dual/quad channel.
But also have to depend on your motherboard layout. Read the manual. lol. :D
enenyi
Okay my bad. I think I was confused with some of the facts too.
koreanlover
Ya I think don't need to be dual channel kit, just get identical RAMs ok aldy.
ragnarok95
Senior Moderator
Senior Moderator
My setup are 2GB/8GB/2GB/8GB. The 2GB kits are corsair vengenance series rams. The 8GB kits are samsung rams.
CPU-Z still show dual channel. I didn't bother to test out whether single or dual liao. :s13:
commach
As long as same chip type, timing and latency identical, it will works as dual channel ram configuration in most cases.
However, for sure fire way, get dual channel kit, if don't work, go flip distro table. :D
ZrE0_Cha0s
but to be honest, most normal motherboard runs on max dual channel from what i know, unless ur mb is one of those higher end and support quad channel, beside that to have quad channel u must get identical set to have quad channel, otherwise, u are just wasting ur money and getting the most efficient setup. :o
mosmos
High Honorary Member
still prefer Kingston, a reliable brand since last time
Pocoyoz
crucial ram rma (send back to crucial) need receipt/invoice or just based on serial no.? :s11:
