Knocking sound from NAS
BlackCube
I have purchased the Asustor AS3204T few days back, only got to setup it today.
Only have one Toshiba 4TB HDD inside out of the 4 available slot. While the HDD is "spinning", there's some vibration/sound which then causes some noise coming out from the NAS. As this is my 1st NAS, I'm not sure if this is a normal behavior.
So is it normal to have like "knocking/cracking" sound every few seconds?
Sorry if I can't explain exactly what it is. I'm trying hard. :s13::s13:
Updated:
Ok, after a little more testing, pretty sure that it's due to the HDD noise.
here's the audio that I managed to get. you can listen to yourself. on your speaker a little bit louder to hear clearer.
https://dl.dropboxusercontent.com/u/7812249/NAS_Sound.mp4
btw, I took the audio from outside the NAS (casing intact).
Alright, some more update. I opened up the casing, changed the HDD slot, and tighten the screw. Here's the HDD noise.
https://dl.dropboxusercontent.com/u/7812249/Open_NAS_Case.mp4
Need to on a little more loud to hear it. I would think this should be normal as HDD is spinning?
And another thing that I noticed is that if I placed the casing this way
It makes more noise with the casing.
but if this way, then not much noise.
ZrE0_Cha0s
Have u tried it on your desktop as well? See if there is any similar sound as well and maybe u can swap in your HDD yo the nas and see if there is any similar sound as well?
batniss
Hv u secured it properly?
AverTek
Suspended
Dear BlackCube,
Possible record video and show us?
Best regard,
JK
xonix
Boot up without HDD, still got knocking sound ?
BlackCube
BlackCube
BlackCube
wacko
I think you have a very low threshold for noise. perhaps best solution is to move the NAS further away from your usual position.
ZrE0_Cha0s
it seems to me the hdd orientations also affects the spindle disk head movement that create the sound? (but still its damn weird.)
BlackCube
It's already away from me. A couple of meters away. Just wondering if it's a issue cause I don't hear such "loud" spinning sound from my hdd inside my casing which one right beside me.
And I thought it was a issue. If this is normal then I'll let it be.
Although the position does affect the sound. It's much better now that I have tighten the screw and place it on the 2nd hdd slot inside the Nas.
Sent from LGE NEXUS 5X using GAGT
