- Jul 14, 2005
Haha.. got increase NB volt? o.o
bo leh... must increase ah =X now stock voltage lor! i set to auto for NB, vcore of cos set myself...
haha.. yeah.. i think you should up your NB voltage... haha XDbo leh... must increase ah =X now stock voltage lor!
haha dont worry i think i reached 1.525v with my mobo to try 4.0 before... and its not stable.. LOLhow high shld i increase sia =X hmmm, just now i increase vcore till 1.5V cos trying 4ghz. once i save settings mobo auto switch off power... turn on den its 1.5V... tink going over e limit le hahahas!
uhh... i suggest you slowly increase ba... dont suddenly increase so much.. haha..
for 3.7 i think.. you can try up by 0.025v first ba.. or 1 unit on your mobo.. lol
haha i dunno ba... use your current settings, the 3.7 one, and up your NB voltage until its stable, then you up your fsb by 2 or 3 units until not stable, then up CPU or NB volts till stable, and repeat till 3.8,3.9,4.0!roger... hahas... 3.8 leh? tink i push 200mhz for now... vcore a bit high sia... scary leh LOL! how bout NB speed? for 3.8 need lower to 1968 bo?
haha i dunno ba... use your current settings, the 3.7 one, and up your NB voltage until its stable, then you up your fsb by 2 or 3 units until not stable, then up CPU or NB volts till stable, and repeat till 3.8,3.9,4.0!![]()
so means NB speed dun need adjust ah? how bout ram? ya lor... can stress dun worry hahahas!Haha good luck!LOL all rites... try in 5 mins =Xso means NB speed dun need adjust ah? how bout ram?
Haha good luck!
do tell me your temps when you reach 3.8... and the settings too.. cause when i was at 3.8, my load temps were 79... XDXD
I fsb from 200 to 225, so my rams are running at 1499mhz at stock volts.. no problem here..ram dun need adjust le ah? let it at 640mhz? ur ram running at its full stock speed or got lower? mine ddr1333 become 1280 =X
depends actually... you test how high your rams can run before it fails to run/not stable.. then from that maybe its easy to guage when to turn down the ram multiplier..
not sure.. my noob opinion.. not a expert overclocker here..![]()
Xigmatek fans soooo nice x.xI would say finally, 4.0Ghz below 60 degrees is no longer a dream![]()
If your talking about the fans on the megahalems.. its actually Noiseblocker fans... mmm :xrepel bro! guess ur rig is up and running!! hahas! DAMN MAN! the xigmatek black fan looks sweets! hahas.. show ur kama bay leh! i wan see!![]()
Haha right right... mah bad thenLOL! i talking abt the case fan! not on megahalemshahas..
lol go take larhs hahas!
