Haha... well your pics on the 2nd page showed that you didn't use the little hole though... you routed two cables across the front of the mobo...unisleeve cables ain't tht difficult actually
More room i find hahas
Must reco lexa S!! i dont see anyone using it lor XDso many K series user
must not reco K series anymore![]()
k52 user here... no fanciful pic.... but 1 thing wanna to ask u guys.... is ur casing v dirty?????
mine is damn dirty sia!!! esp the front of the casing where the front fan is.... wdf... have to clean regularly.....
i find it unnecessary... at least for my case... my 220mm side fan causes my gfx to have its load temps to be 2 degrees higher.. :x
He's planning to get that rig in nov/dec.. :x
sometimes the heat will get trapped at the graphic card area, thus cus the gpu temps to increaseo.0 so werid i thought fan will blowing to ur gfx will make it better? why ur 1 worst?
sorry las now collecting info![]()
then u should be fine, sometime, some ppls the casing TOO positive airflow liao, hot air all trapped insideohhh... hmmm i just adding one more side fan 140mm ok rite?
but how the heat trap inside ? we got fan blowing into the gfx.
the rest of the 4fans will be normal.. 3 exhaust, one intake from the front.. + addition 1side fan 1400mm![]()
Ok third round of cable management
hi all, may i know where did you all get this casing? im looking at the price list of bizgram and fulwell, but cant find. whats the cost also?
thanks
