Lancool K-series Users Group
FastForwardToFriday
hey FFTF.....
Can post a pic of your K62 with Kama bay? might want to get one too
here you go:)
do rmb if you are considering puting a GT you would like to buy addition screws as the one provided cannnot fit GT mounting holes. so i use cable ties for the moment.
Aeroplane.
Why not just get some bluetack and stick the fan to the 5.25" Bay there... Kamabay really expensive for what it offers..
lcheowl
here you go:)
K62 air flow is very good already, the temp drop how much after you added one more fan?
Btw has your hawk reset before when you play games at highest setting?
FastForwardToFriday
drop abt 2degree.. lol.. feel like changing hs to megahaleams! yah last time, its the driver restart, just need to up the voltage to make it stable.
tErOn
abit sad dat the k63 still has no bottom intake..even with 2 front intakes cannot beat the 3 exhausts rite? unless top exhausts reduced to only 1..still negative air pressure case..
=_=||
FastForwardToFriday
Noctua NH-U12P SE2 is quiet and cooling. Just that, the colour need to take time to get use to it.
haha! i was thinking of tat first then decided to go for hyper 212+, maybe 1 or 2 years down the road i will change to megahalems then can oc even further:)
Milo-Dino
why your hdd/ssd install the other way round? :s11::s11:
hmm fortran did the setup so i didn't really bother.
The reverse side is quite cramp I feel... quite abit of cables over the other side... so I don't really wanna take out that end if I need to check the sata cable also
akboiboi
i heard some people say they can rotate the hdd cage 90 degrees around is that true for the k62? i've been trying to turn it for some time but canot seem to do it lol
hystify-
hi guys, just to enquire.
my 5-day old k62 started emitting humming noises, which i suspect is from the top fans. i took a cushion and laid it on top of the casing, covering the 2 fans and the humming stopped.
should i get some silent fans to replace the top exhaust fans, or anyone has any solution that solved the humming problem?
