Lancool K-series Users Group
Milo-Dino
@milo, how come your rig so bright? you add blue CCFL?
nope... just took it in a completely dark room and play around with my canon s90 settings :p
was taken handheld at ISO 1600 with 4sec shutter speed... that's why abit blurry
lazy to find the mini tripod :p
tErOn
My one week old rig
Gratz on the new hoots! time to add another blue LED front intake at your dvd bay..
i heard some people say they can rotate the hdd cage 90 degrees around is that true for the k62? i've been trying to turn it for some time but canot seem to do it lol
wah..dat one i oso nv try..bt care to share y wud u wanna do dat?
hi guys, just to enquire.
my 5-day old k62 started emitting humming noises, which i suspect is from the top fans. i took a cushion and laid it on top of the casing, covering the 2 fans and the humming stopped.
should i get some silent fans to replace the top exhaust fans, or anyone has any solution that solved the humming problem?
hmm..mine got since last april bt dun have humming sounds leh..this isnt normal ba..maybe if u can isolate the problem u can replace it?
changed casing from nzxt to this.. so much better :D
gratz on the hoots and welcome to the club!
Milo-Dino
I suspect it's more to your Noctua cooler...
My GTs have noise as well... and it's not the top 2 lian li fans because I tried unplugging them and still got noise :p
Milo-Dino
Considering.... might add a AP121 led
Also considering to get a lamptron fan controller to turn down the fans when I leave my rig on for overnight downloads or maintenance :D
vivi2005
K62 you can remove the top screw from the cage, and 2 other more screws at the bottom of the case. After that you can move the cage to rotate it. I already rotated mine so my hdd connectors face the motherboard.
tErOn
hmm...actually for me i prefer the hdd connectors face away frm the mobo..hw come u wan your facing the mobo?
vivi2005
Each has it owns preference ba last time me is face inside with the cables hid inside cant see de, den after awhile change to outside cause easier to take out and troubleshoot. See until sian liao now change to facing mobo :D and is easier to connect my sata cables.
Aeroplane.
long time no post here.. :)
tErOn
wahaha..almost all directions u tried liao..i agree its easier to connect the cables..for this case its still gd cos the sata cables dun cause much obstruction..where as for my en2..its :s22:
nice pics! twin fozr unisleeved and liquid cooled!
hystify-
i just tried opening the side panel and covering the top fan filter cage. put my head beside and listened, no humming at all.
so i guess the problem lies with the way the air moves up and out of the cage, probably bouncing off the filters or what, and not problems from the fan. guess i'll have to live with it then, lol.
tErOn
wah...your hearing is damned gd liddat..i cant hear anything noticeable to irritate me..previously i used an excalibur as rear exhaust..wah..sibeh irritated..used less than a few wks..changed to the xigmateks liao..lol
