have to save up, no choice. in the meantime, need to do a lot of reading, i am way behind in the IT world.
Haha, feel free to ask us if u have any queries also. We would be glad to help u out
Around an hour plus with this casing for KeYoKe. Hopefully it doesnt look too bad. No cable ties!!
Too bad the 8pin ATX wasnt long enough to go behind the casing![]()
Wa, HD5870. Makes me feel sad
Haha, u mean side fan in ur side window? Yea, the megahalems will be able to fit in. Whats ur budget for CPU cooler?
Casings with grills are like that one lah. Next time don't buy anything with grills loh.
But I assume your K52 comes with dust filters???
So are the stock rear fan, and blue led fans(x3) any good? Interested in this chassis, so wondering if i should replace them for my OC-ing.
Should be good enough. Unless u want to change the fans. Which might be quite costly for a 140mm fan. And i believe OC depends more on the CPU cooler.
Yes, but OC-ing heats up basically the whole mobo, i wonder if the stock fans are capable of dissipating heat fast enough than 3rd party.
Side tracking, would a V6 fits nicely onto a K62?
hi bros, anyone know where i can get green led 140mm fans for the front and top?
been looking out for it but dont seem to able to find it![]()
Xigmatek Green crystal series?
Only 140mm green fan i have in mind![]()
any idea where can i get it from?Xigmatek Green crystal series?
seems like i can only see the red or blue ones most of the time
@kaixax: lol, well i happened to be selling my c2d and mobo, so since its a good offer i just traded it.
http://forums.vr-zone.com/singapore...d-cpu-coolit-eco-advanced-liquid-cooling.html
link above for anyone who is interested in a all in one cpu water cooler and has an spare old c2d proc![]()
Green 140mm is a pretty tough option. Cause its quite hard to find. Can try looking at Scorpio and Prolinkdata. Uvinium might have their own 140mm green fans also.
Not considering other colours?![]()
not really, want black+green themeGreen 140mm is a pretty tough option. Cause its quite hard to find. Can try looking at Scorpio and Prolinkdata. Uvinium might have their own 140mm green fans also.
not really, want black+green theme![]()
change to gigabyte P55A-UD3 lasuddenly wish to top up + trade my H55M-S2H for P55 GD65...sian...
