Lancool K-series Users Group
Kzhan00b
xboxer
How many "free" fans does this Lian Li K62 come with??
And are they good??
KeYoKe
3 x 140mm with blue led Lian Li (1 intake at front... 2 top exhaust <default>)
1 x 120mm normal fan Lian Li (exhaust at back of casing)
KeYoKe
Enough air? Noisy or not?? :s11:
definitely enough... nope... i got the same fans running on my cooler and old casing running in the new casing... and im really happy that the sound level is so much lower den my old coolermaster c5
edit: CPU idle temp lower by 4-6 degrees with this new casing
tErOn
Dats a nice one for u..i find my casing pretty silent too..even tho its on the table right beside me..
My fan set up was as follows
Front:
Below 140mm bundle casing fan
Top 120mm Xigmatek Blue Crystal Series
Top:
Both 140mm bundled casing fan
Rear:
Replaced non-led bundled fan with 120mm Xigmatek Blue Crystal Series
CPU Cooler:
2X 120mm Xigmatek Blue Crystal Series
Yes my case fans are all blue LEDs..some Xigmateks some Bundled..
love it nw..low noise no FC used..i previously bot an Excalubur to use as rear exhaust..bt its noisy as hell..compared to this..its tranquility man..my ceiling fan cancels out the casing noise..i have to put my ear right next to the casing to hear the fan noise..
repel89
Front:
Top:
Rear:
CPU Cooler:
Too much bling for me!!! Haha. Stock K62 fans are pretty silent but quite slow moving. Waiting for penetrator to come ;)
xboxer
More and more gian this K62 now. :love:
There is a added advantage of steel casing over alu, other than cost, is that it "vibrates" less and produces less noise than a lighter and thinner alu casing. ;)
KeYoKe
yup... lemme poison u... please get it LOL! i like e casing alot and its super silent =) but 1 thing bad is that its super heavy
KeYoKe
Front:
Top:
Rear:
CPU Cooler:
Thanks bro... yea im dam happy with the casing man... =) :s13::s13: good air flow... hahas my on load temp is 44 degrees with OCCT. previously 50-51 ;)
justln
Yea I'm a proud owner of K60, the fans aren't a problem at all, can't hear them at all.
Damn heavy though. Have a hard time moving it around if I want to install new hardware/clean it.
The grills infront trap most of the dust so I just use a normal brush and sweep away the dust balls. :s13:
kaixax555
Fans are okay...they do their job well
39 degrees idle stock cooler non air-con room is good enough
