BunnyPancake
Suspended
- Dec 23, 2005
We were always told the 'benefits' of it - it saves electricity and can last very long, blah blah.
But then when you ownself want to replace, it is a bit complicated. Either need to hire handyman or ownself refer to tutorials and ownself figure out.
I managed to do ownself... But it is hell. I cannot replace it at night then must endure until next morning... Have to use table lamp. Then next morning when want to replace, must unscrew so many parts. Then I realised we got tricked because we were told LED light could last 5,000 hours or what, but then when I counted it barely even reached 2,000 hours as advertised.
And depending where you installed the LED light, it can be pointless. For example, toilet... You don't use toilet for hours what. At most, at night or during dark rainy days, and you usually just use 5-30 mins max.
And if you notice, the LED lights are usually in serial connection (one connecting to the next), so if suay suay after the first LED is burnt, the rest all cannot on liao since there's no 'closed' circuit. And you don't know where is the fault sometimes, the connection or LED adapter.
When want to replace, usually must replace the whole damn thing... Then must unscrew here and there, and replace the compartment just to slot out the LED parts.
I rather stick to my old 8 watt light bulb sua. Just unscrew and put in. Easy.
Also, replace normal light bulb - $5-8. Anyone can do, even your parents or grandma or grandpa.
Replace LED, $15-20; if hire handyman add in $30-50.
