I use this in the kitchen. Very bright and last a long time.Anyone using this type for rooms?
this 1 is for thin wiresthose LED ceiling kits like to give these tool-free connector free
i used it once ..... 1 week later it loosen because the wire itself don't like to be bend .......... since then i rather use back my own connectors the traditional screw type .... too many in toolbox cannot use finish for decades
ufo type focus more to downward and less wasted at shining sideways on wallAnyone using this type for rooms?
At most 3 for the E wire.only two wires leh... nothing to unscrew
dun bluff us ok
Unless his contractor cut cost by tapping the wire from 1 to another. That makes it 4 to 6 wires.
Using this Phillips UFO LED bulb for store room, I think mine is either 40 or 60w daylight, it's very bright for toilet or storeroom
I will buy another one to replace another dimmer LED, when it breaks.
the maximum is 24watt only i think
if the ceiling socket is at middle of room or kitchen ...... if what you are doing is near the edge of the room and facing the wall .... example cooking on stove , reading on desk ....... your head will directly cast a shadow and make your task darker , cannot see into the cooking wok
second bad point is the ufo ontop collect dust and oil more than pineapple shape bulb ....... pineapple shape philips have up to 50watt in e27 socket
Sorry, need to clarify: what I meant by "unscrew many things" is the fixture...only two wires leh... nothing to unscrew
dun bluff us ok
only philips brand uses real wattage ....... label put 24 you can really get 23watt on power on ...... as it heat up it drop to 20wattWas thinking of using this type of E27 ufo led light for rooms. Saw some up to 100w on Lazada.
So this type isn't suitable for rooms?
Won't electrocute unless those kam gong go change with the power still on.You must unscrew the thing and screw back properly
Good luck if you electrocute yourself
Can use for rooms, because of it's IFO shape, it's meant as ceiling light which have a far throw of the light, I suggest getting at least 60-100w. I bought this from Mr DIY around $30-40. Btw u got to check your bulb holder base is screw or the pin type, usually it's screwWas thinking of using this type of E27 ufo led light for rooms. Saw some up to 100w on Lazada.
other no brand china led ..... label say 100watt ....... u only get 30 to 60 watt when you power on and it dips further as it heat ........ 100 only worth's its printed ink to get you to buy , totally unreal
you don’t de-energise the lighting circuit before you work on the light??You must unscrew the thing and screw back properly
