Let's Accessorize Your S7 / S7 Edge
siaoz85
Using Dataflex SP. A lot of casings will push it up. SGP and Ringke. Once pushed up and the slightest dust gets in, the sides will never stick onto the screen again.
Anyone else saw where got sell glass screen protector which sits well and reasonably priced?
Sent from Samsung SM-G935F using GAGT
LesterQ
Sgp ultra hybrid or the ringke fusion also push the sides up?
Will be pasting the SP soon.
onefineday
Bought the spigen film sp for S7, the sp is unable to fully stick as the screen is slightly curved. Will probably leave it and wait for a decent tempered glass sp to come out.
Also I got the clear view cover using the $100 pre order voucher. But then i realise that the clear view cover does not work with the always on display. When you close the cover the display will switch off.
Designing a flip case with a transparent cover but does not work with the always on display... kinda stupid isnt it?
luv_boa
Screen protector for s7 shld be easy to find as compared to s7 edge?
gapboy
All edge devices are near impossible to get working properly tempered glass as I own sS6 edge before usually a good film does the trick
luv_boa
Anyone manage to get a fitting screen protector for s7 at Tampines?
malaikai2005
I went back ..home
just use my current s5 charger to charge
ok leh ...heehee
maybe slower?
my charger still inside packaged
heehee
lazy to open yet
later I go starhub replace my micro sim to nano:s12::s12:
extremeOH
I am also looking for one. Saw a tempered glass at IT show level 6 for $8, free installing some more. But worry too cheap will have problem using the screen. Think better stick to plastic film.
luv_boa
Level 3 of Tampines mall selling plastic at $15. I hope it will fit well
extremeOH
I went back ..home
ok leh ...heehee
maybe slower?
heehee
lazy to open yet
Mine is S3, ancient. That time fast charge is unheard of.
CatLuVer
Just now my sister asked a few shops at Funan,. All don have screen protector or tempered glass for S7 Edge
