Let's Accessorize Your S7 / S7 Edge
S750WP
S7 tenpered SP is now available from Taobao.
Sent from Samsung SM-G930F using GAGT
K.laus
S7 edge with film type dun goes with UAG. It will flip up. In the end just bought the UAG Ash. UAG Case with naked front
LesterQ
Guys. Screen protector found at Seletar Mall basement Beno mobile.
Tempered glass is $55 only gold.
Silicon screen protector is $20.
I've took a look at the tempered one. Looks legit. But I think it'll not be easy to get the alignment correct.
Please take note the non tempered glass screen protector is does NOT fully cover the edge. It's just a S7 protector.
jamesbach
Just got plastic sp at mobile square. The quality not very good although it does stick to the edge. $20.
feeler
Managed to buy a Healing Shield Curved Fit. Covers edge to edge and once installed you would hardly see there's a screen protector. Bought at Nex just outside Popular bookstore near the cinema. Cost me $19.90.
doomgaze86
Are you using it with a case? Are there any issues?
royfrosty
Hi guys, just came back from p2o mobile. I gotten their flim protector at $19. Not bad leh. At least got some oleophobic coating which i find it awesome.
Note that not all casing can fit the flim. Some are Ringke Fushion and Spigen slim fit.
chaud@sg
The $19 sp can stick to the screen properly? I bought the $25 front and back sp from them earlier today. The front screen protector like not holding to the screen very well sia. �
Sent from Samsung SM-G935F using GAGT
royfrosty
The $19 sp can stick to the screen properly? I bought the $25 front and back sp from them earlier today. The front screen protector like not holding to the screen very well sia. *********
So far mine bo taiji. Really
LesterQ
P20 Mobile is the one where Adix used to work at?
I pasted at the "Adix" Shop. $12.. :p Ringke Fusion seems okay.
G4
i actually brought the screen protector from the samsung store for S7. kinda regret cos it cover not even until the screen starts to curve. as a result some icons are partially covered.
any idea to get those screen protector that cover better? my case is the spigen ultra hybrid.
liewjinyun
sorry if i can't help at all. just wanna ask, do you have any bubble/halo effect at the back? where the case and glass body comes into contact?
peacefulday
I did post some time this morning regards the issue --->
punggol waterpoint's singnet shop, mobile shop and x-gear are selling tempered glass protector for S7 only. Think for S7 edge only plastic film is available.
x-gear S7 tp's glass width is shorter but look weird as side look 'lobang' as not covered;
mobile shop S7 tp can better covered the S7phone's width but you will notice 'bubble gap' due to S7's is not flat at width's rim.
I regretted and re-purchased the 'duraglas japan premium tempered glass' from the mobile shop, it's definitely look much better although there is some flaw gap at side
G4
yes, there is, not bubble but patches of halo. think its inevitable cos of thee TPU, unless the surface is matt as the spigen case of my Z5.
Arceptionist
So can I clarify that Mobile Hardware at Burlington Square has the healing shield edge cover?
I think I'm going down on Monday to go get myself one
