kelvinti
- Jan 5, 2009
How come ? You mean later batch Pro2 has better camera. How to know if mine is in which category ? Can post to show the different camera output ?Hmm... After getting the 2nd new set, I realized that my camera is over exposed after comparing the camera on the new set.
Checking with LG Service now to see if the camera module can be replaced...
1 weekend into using this phone and im really satisfied with this phone.
Bright and big screen, pretty decent camera and extremely good battery life! Never really quite got over note 2 after I changed from it to Sony Z1, but this pro 2 is really better than the previous 2 phones. While G3 seems better in most aspects over pro 2, I dont think I need a quad HD screen currently and better battery life is more important. Wont hestiate to jump to pro 3 if LG continues to keep up the good work.
Agreed.
Never thought I could get over my Note 3 but this phone had really exceeded my expectation.
In case if you're not aware, battery life and APP speed can even be better if you were to use ART rather than Dalvik. Though with the expense of higher apps storage, this however not an issue with G Pro 2's 32GB and expandable memory.
This may be possible.
I compared G Pro 2's camera few months back with my Note 3 and find that note 3's picture is sharper with more details.
When I bought my G Pro 2 last week, I'm surprised that the picture produced (especially in 'normal' mode) has the same sharpness or even better than Note 3 in all lighting condition.
Btw, would like to check with all experience G Pro 2 owners here, where is the manufacturing country of your set? China or Korea?
Thanks.
Yes. And u can put it right before warranty expires. Otherwise, still gong gong using it.Well,
Everything happened for a reason.
Without getting the new set for my little bro last night, I would have never realized that my own set has some sorts of problem for its camera after 5 long months LOL!
It's a blessing!![]()
Where u got the g pro 2 white and how much? Any M1 dealer shop got stock for the white?
Hmmmm. Let me see if I can replicate the same camera error
I also don't get well defined street lights.. not sure if my camera is also defective ..For my case, the so-called defect is when I'm pointing or focusing on the lamp, light bulb when that happened.
I have particularly hard time or impossible getting a clear photo under street light too when the white ghostly effect from the street light just simply whiten the shots.
On my new set, it doesn't happen. All photos taken under the above mentioned circumstances turned out to be natural and super clear and crisp.
I got it from Bazaar here.
Not sure about retailers. Call them to check and reserve.
