LG G Pro 2
anirudhks
Bazaar? I wanna get one.Urs new sealed set?Any particular person u get from?
bro just sold my Pro2 a week old at Adix bro shop , however there is a set at redwhite as well , thats black , and also the one i sold to Adix was black .. I got a new one from him ( White ) at 630 , you may wnna check if he still has white stock.. i kind didnt like the glitter finish on the black phone so went to white again
kelvinti
My 2nd set of Pro 2 is also white. :)
kelvinti
Can show us samples cos dont think most have another pro2 to compare leh...
Okay. I retook 3 photos using the "normal" camera on my little's bro new Pro 2.
You can compare them with the 3 photos taken using the "abnormal" camera on my own Pro 2 which had been sent for checking yesterday.
Note: Top is the "abnormal" Pro 2's camera. Bottom is the "normal" Pro 2's camera shots:
Photo 01
Photo 02
Photo 03
Noticed the horizontal white light lines?
Isn't it too obvious? :eek::s8:
lgmw33
Photo 01
Photo 02
Photo 03
Thanks for sharing.
My pictures of street lamps are not really defined though without obvious horizontal lines...
december_blues
To all g pro 2 experts here, do u know how to do hardware reset (recovery menu) ? I tried the holding the power and down button method but doesn't work.
Thanks all.
progene
By the way, do you guys have this option.
Natural flash feature in your camera.trying find this buy unable to find in settings.
Advertised in LG website.
LG G Pro2 camera has incredible features. Natural Flash takes two shots automatically—one with flash, the other without—and merges them for a single shot with the best exposure and color temperature. And Magic Focus lets you switch the focal point from one object to another after the photo has been captured
kelvinti
Hmm...what it means is that the flash installed on the phone is already a Natural Flash already. No need to choose any setting or cannot be selected at all bah...:s22:
kelvinti
Thanks all.
How to Hard Reset LG G Pro 2 :s22:
Hardware factory reset
Turn off your phone; if you can’t do it as usual, then press power button for about 15 seconds.
After shutting down your device, press volume down button and power button together and at the same time until the LG logo appears on the screen.
When the LG logo is displayed, let go of the power button, but keep pressing the volume down key.
Now press once more power button.
Once you do that, on your LG G Pro 2 the factory reset menu will be displayed.
Press power button in order to agree and wait while the hard reset is being completed.
Then, if you want you can enter recovery mode for clearing cache and for performing other operations.
Go back to Android OS by selecting „reboot system now”.
Perfect, you have successfully completed our dedicated step by step guide. Therefore now you know how to make a hard reset on your LG G Pro 2. If you still have problems on your device, stay close as a compatible “unbrick” tutorial will soon be developed and there you will find detailed guidelines that can be used for fixing your Android based smartphone. Until then, don’t forget about us and use the comments field from below for sharing your thoughts and experience with us and with our readers who might also want to use this tutorial.
kelvinti
I use the default camera settings. Image size, 13M, 4160X3120 (4:3).
Should use 16:9 bah... Photos look better.
Anyway, hope that my own Pro 2 will be back from LG service, latest by Saturday with a fix on the abnormal camera coz my little bro is already making a hell of lot of noise that I have robbed his new Pro 2 ;)
I think I have to pay him some $ for loss of usage to make him happy...
progene
Just buy ur bro another LG G Pro 2 lor.
Anyway, the camera setting under image size has these.
> 3M 2048X1536 (4:3)
> 8M 3246X2448 (4:3)
> W10M 4160X2340 (16:9)
> 13M 4160X3120 (4:3)
So naturally, I selected 13M. But really has no clue what is all these so choose 13M. This should be 13megapixel ba.
But why 16:9 is better?
kelvinti
> 3M 2048X1536 (4:3)
> 8M 3246X2448 (4:3)
> 13M 4160X3120 (4:3)
Oh! A photo that has the 16:9 ratio looks more appearing and it is a standard ratio in every prints everywhere lol...
