kelvinti
- Jan 5, 2009
Personally, I'm using this case now at the moment.
Wow .. so cool
Yup! IMAK clear case is pretty good!
I used them before too on may phones.![]()
After the 10b update months back, LG G Pro 2 has been very good and problem free!
The next big hope is that LG will port the G3's UI to Pro 2 asap.
As for Android L, I think that the chances are slim as by the time Android L is officially released, Pro 3 should be out then in February/March 2015.![]()
Imak for G Pro was good. But I was disappointed with the Imak on Pro2. A bit shaky, cover not so fitting. Not sure if same supplier but packaging is different from yours ...Yup. Imak good. Used it on my previous G Pro too. Pro 3 would be a Note 4 Killer like it's predecessor.
But mostly skipping it maybe till Pro 5. Buy pray that Android L will come to Pro 2
Hi users of LG G Pro 2,
I am going to get this phone but is rather concern about the battery life of this phone as quite a number of reviews mention that the battery drop significantly after a while even when not in use, worse when used actively like play games and watch movie. Still quite concern although really like the phone because of its big screen. Although battery life likely to be short as the screen consume a lot of power plus the many useless apps running on the LG OS. Thanks fr the feedback.
Is the imak for pro 2 0.3mm thin or thicker?Imak for G Pro was good. But I was disappointed with the Imak on Pro2. A bit shaky, cover not so fitting. Not sure if same supplier but packaging is different from yours ...
The Imak mentioned is clear back cover, not screen protector. .Is the imak for pro 2 0.3mm thin or thicker?
For your info, several friends here gave up G3 for Pro 2.If u are going to get a g pro 2 now, mught as well get the newer g3.
