LG G Pro 2
stamina
The Imak mentioned is clear back cover, not screen protector. .
I know.my other g2 cover is really 0.3m thin.so its really thin and fits well.unlike those mercury brands where its thick and spoil the overall sleekness of G2.
lgmw33
Is yours ultra thin silicon or hard plastic? Imak is hard plastic.
lgmw33
I think mine is hardplastic but very thin and soft.u just google 0.3mm g2 cover.cost me only less than S$3 when I buy online.
I am waiting for such cover for Pro2. It seems suppliers are more for G2 n G3. :(
kelvinti
Don't' have 0.3mm for Pro 2.
My long time eBay seller, Dreamviva said there is non in the market.
Dreamviva has a lot of 0.33mm case for all kind of phones except Pro 2.:(
mosh11
Personally I had consistent 7-8 hours SOT on it (80% on 3g/wifi ) . Best phablet I had used vs previous HTC one max, xperia z ultra, ascend mate. Battery life is EXCELLENT n only my mediapad X1 beats it (12 hours SOT). I rooted the phone n coupled with xmod, intelli3g n greenify , on standby with 3g n wifi on battery level hardly dip eg over 7 hours hardly even 1% battery drop.
after upgrading to d83810f , I am not happy at all with my battery consumption . what mods did u install on Xmod ?
kelvinti
I like the design of Nexus 6! Some more, it's a 5.9" screen, same as our Pro 2! :)
I can handle the size for sure! ;)
May be I will buy Nexus 6 as my backup phone! :D Got free lollipop to lick! :D
lgmw33
May be I will buy Nexus 6 as my backup phone! :D Got free lollipop to eat! :D
Yes. I like I like. Screen 5.96", specs ideal. Somemore front speakers :D
Only bad is built-in battery plus amoled display which i am not in favour :(
Really need to see demo set to decide.
zzcalvin123
nexus 6 is a massive upgrade from the nexus 5.
9N1Y9N1Y
anyone have problem with LG Smart World? when i click to enter app it crash "Unfortunately SmartWorld has stopped"
kelvinti
Do this:
> Settings > Apps > LG SmartWorld app > Clear Cache > Clear Data > Force Stop > Reboot phone. :s22:
It should solve the problem. :)
