LG G Pro 2
kelvinti
Bro why do you use Screen Off when you can double tap the status bar on top (or any empty home screen space) to turn the screen off on its own. :s22:
Ohh! Coz I have no empty space left in my home screen leh.
Also, I don't wanna stretch my finger all the way to the top of the phone to off the display. Very troublesome lah.
That's why I put the screen-off in the middle of the dock for easy one hand operation in any pages ...!)
I'm so use to sxreen-off..haha.
devilot4
Was your purchase originally from starhub?
If not, when first turning on your phone with the simcard first inserted, be sure to NOT DOWNLOAD the simcard settings when it asks you to.
I accidentally tapped Yes and immediately the starcrap logo appeared on startup along with all the other bloatware.
I hard resetted the phone and made sure I tapped NO. Afterwhich there was no more strabuh logo...
Hope that helps... :s8:
Thanks bro, I recontract my phone with M1, went back home n put in my starhub sim card. oh, i tried to follow your steps, what i did was off my phone n took out the sim card, on and off and put back sim card and on again, but it didn't ask me to download simcard settings leh. And yeah starcrap logo and its other bloatware all appeared again :(
Is there a way to get to simcard settings etc?
kelvinti
Okay. Battery left 17% now.
Stat:
Brightness level = 40% with occasional Auto when outdoor.
Total Usage on Battery: 13 hours.
Screen on time = 4 hours 34 minutes with various apps.
8 Ball Pool online game: 43 minutes.
Not too shabby for a single charge since this morning. :)
The bad thing is that I don't have enough time to recharge the battery now as I'm rushing out in again in 1/2 time.
The good is that, I have a fully charged spare battery to come to the rescue in such critical time. ! ;)
Chipero
Usage on battery = 11 hr 44 minutes
Brightness = 50%
Mostly whatsapp.
Battery left = 50%
Tuakong
Brightness setting on my phones is usually 70% :D
Any lower and I cant get use to it
Tuakong
Between the Xperia Z series and G Pro, I will take the Pro/Pro2 anytime.
The water-resistant feature on the Xperia Z is useful though
Just now at JP Gadget World I had a feel of PRO 2, wa KNN sibei chio slim and shiok feeling. Screen is big. The back button can power on & off.
Than went over to Sony Centre, see the Z2 screen thou the played spiderman2, thou the colors swee and vibrant but somehow when I held the Pro2, it was like "TAKE ME HOME MAI TU AH"!!! :D
But gadget world selling at S$828 ah, the most they throw in screen protector and a case.
Chipero
I bought the Z once .. returned it to dealer on the 2nd day. The ringtone .. Zzzzzz
noobzpro
think this is one of the first cases wifout any antenna hole from germany...
noobzpro
Inertiaholic
factory reset
Chipero
My Gpro2 white is having the same camera problem again. Its starting from Intelligent Auto with flash on ...
kelvinti
My Gpro2 white is having a camera problem again. Its starting from Intelligent Auto with flash on ...
Hmmm!
Strange! 2nd set also got the same problem?:eek:
Is it that iAuto should not be used with flash? Operational problem?:s11:
Reboot and try iAuto mode without Flash to see how it goes...!:s8:
If the problem persists, I will help you to ask the LG Pro 2 technical folks next Monday during the photography event...
Chipero
wat?! u got a new set already right?:eek:
Hmmm!
If the problem persists, I will help you to ask the LGG Pro 2 technical folks next Monday..
Its only the iAuto with flash on , got problem. The rest all seesm fine.
Rebooted many times le.
You guys help to try please ? Randomly take iAuto with flash on in bright lit room.
Take a few still ok ... I took like 30 such pictures no problem after that the screen will freeze. Cannot press anything other than the osb. When you go back to the camera app again, everything on the screen will either be completely white or completely black when you are in a bright room. Take picture all white or all black. Then gotta reboot again.
Thanks bro. I just rebooted. Normal with flash on or off no problem. The moment I switch to iAuto flash on, screen freezes.
kelvinti
ps nvr put link
Silikon Hülle LG G PRO 2 X Style Weiß TPU Case Schutz Cover Schutzfolie | eBay
Silikon Hülle LG G PRO 2 Transparent Türkis TPU Case Cover Schutzfolie | eBay
8+sgd free shipping hoot dah! the other colours all from this seller...i think this transparent turqoise is pretty nice wif a white backing
Semi transparent TPU, reasonable thickness! Very seductive! I like it! :}
Since it's just 8 bucks and with free shipping, can order it as a standby case as well as a rough outing protection case! :s22:
Okay lah! I hoot one first..the rose red one!:s22:
noobzpro
MAYBE could be the pic u taking of? Anything steamy and hot like ur DP?? :s13: Jokes aside maybe try factory reset or something?
kelvinti
I see. Could be a bug. I will ask LG for you comes next Monday!
