LG G Pro 2
kelvinti
Help! My camera something wrong. Tried to take pic wif different modes. Suddenly the screen went blank. Can still take pic but i cant see wat im taking. Then now even i on flash, still no flash.
Usual issue at times with camera in smartphones.
Go to Apps, Camera, clear cache, reboot phone to see how. ;)
Persie
after spending sometime on shopping for a cover online, noted not much choices...end up only buying the Nekeda back case and tempered glass protector...may also get a window case but already a bit sick of it during my G2 time.
very tempted to use this naked but scared dirty cos mine is white. Plus i scared the metal parts will be easily dented just like the sumsung galaxy series phone.
Unknownx
Underrated/non-mainstream phone is like that... Very little choices on accessories
But GP2 still better, I've used few phones before that only can find clear/matte sp + tpu case only lol
shorty07
done...now the flash still not working. tried taking in low light with auto flash, no flash. on flash...also no flash. haiz...:(
noobzpro
Ask u all ah...immediately paste glas sp. Or paste normal use a few days first? Or check on spot enuff le. What to look out for for this device
kelvinti
I have been using my white GP2 naked since 27th March too awaiting for my 3 cases to arrive from eBay.:)
Just have to be extra careful! At least I do my best. If anything to happen to my GP2 like dropping it, get dented or scratches. It is fated.:o
kelvinti
POwer off the phone. Take out the battery. Wait for 10 minutes. Put it back and power on..to see how it goes again!
If it still fail, then factory reset is the last possible solution..:o
shorty07
for factory reset, everything will b gone, right? will my contacts b gone? for apps i don mind, since i jus re-install cos couldnt "bring forward" fm my previous phone.
kelvinti
If your Contacts are Google connected, and have been synced, they are saved and safe.:)
Just perform a sync of all your Accounts before you perform factory reset. :)
shorty07
haiyah...give up liao. take out batt n on still no flash. jus to confirm....u can see the flash light up, right? cos i was reading n saw something abt natural flash, chromaflash...
Chipero
Goto Accessbility >> Flash Alerts .. try incoming calls or whatsapp, see the flash working anot ?
kelvinti
no flash. only the green light at the power button. means my flash spoil is it?
Hmm...could be a lemon flash.
So, you have got no choice but force to perform a factory reset to try to fix it before heading to LG...
The flash is very bright one.
jazzman80
I'm heading to there now. the chip of the SIM tray broke, caused by the SIM card adapter. heading to M1 request change of micro SIM hopefully FOC.
shorty07
ok confirm flash spoil. use flashlight app also no light. basket...first time buy lg phone, n first time encounter defect after so many phones used. suay....
