xxxbillybobxxx
- Mar 8, 2009
Where can I find the 2016 B6, for $2,300 (55-inch)? Been seeing it higher.
Thanks?
Thanks?
Thanks?
Is $3k for OLED55B6 worth buying? Or better off buying C7?
Oh wow... Thats silly.look carefully. i think the 2990 and 5480 price is for the model written in small print directly above the price. common trick.![]()
Not enough post to PM you. Try Courts outlets which still display their B6. Pls remember check their display lifespan.....
Under the TV menu... U probably need the sale guy to do it for you cos you need the remote controller to access the menu.Do you know where to check the lifespan of an LG set?
MEGA has a roadshow at united square. Anyone went and see if got good deals there?
Where is united square?
Novena. Beside Novena square. You planning to go see?
Gamxia, will pop by mega n ssrrThe c7 is sold at most stores that I have seen.
Cool thanksHarvey Norman Millenia has C7, E7, G7 (77"), even the W7 on display.
I don't think it's worth buying.
You do get 3D with the C6 over the B6 though.
