Looking for a small form factor build
asdsker90
Looking to get a mini-ATX build to replace my micro build from 4 years ago to save space.
Will keep the following items:
Zotac AMP! 6GB
Samsung SSD 1TB
Samsung SSD 128GB
seems like there are alot of Ryzen Builds. Are they good?
Alexls
go small or go home
singupingu
Is overheating a problem? Especially with rtx2080ti and i7 9700k
Depends what kind of hardware you're putting in and how good is the ambience ventilation is.
Being small, all the heat is expelled immediately.
Blower type gpu is the way to go, open air type is acceptable but don't expect all out OC. 9700K I doubt you can. Those 9th gen Intel is so hot, it's ridiculous when ppl used to say "buy Intel coz AMD is slow and hot". How things had changed with AMD Ryzen efficiency honestly.
Sent from OnePlus ONEPLUS A3003 using GAGT
Shutterbox
any compact casing that support mATX and has decent cooling?
I know of some lian lis, Corsair carbide Air 240,silverstone and some jonsbo models.
basicall models that are around 310x310mm (height and width) or smaller
gld998
I using this for 1xRyzen 1700x and 1x6600k.
Not bad! Using 120 AIO with it. Got 1x at 20 in caraohell and another at 35
wwenze
While for other card the air is sucked in from the side of the case...
