looking for mouse recommendation
elmariachi
Wonderful and you're too kind. I'm considering the x2v2 mini with my fingertip grip.
Sure then better off to get locally then. You should have no issues though sticky clicks is a hit and miss. I think Pulsar only rectified it in the Special Edition mouse releases so see if you can get those ones as it will be much less likely to have this issue!
Cheers!
Steyr69
This one is the dragonfly series right?
I was looking at taobao vxe flagship store yesterday.
The white one OOS. Left black. It was on discount at RMB 89.
This morning I re check, OOS liao. The price also revert back to RMB 159.
Really selling like hot cakes.
The pet peeve probably is it cannot do 4K polling as reported on their website.
Only 2k. Got one youtube voiced this out. Got blasted by others as being too picky .
The offer RMB 89 is back!
For both white and black !
On Taobao.
Steyr69
I am actually using this very old mouse MS Notebook Optical Mouse 3000.
It is small. Been using it for like 10+ years.
Very happy with its performance.
I don't game though.
Was thinking are there any new alternatives?
tigerwoods
【淘宝】https://m.tb.cn/h.g0X0BASEmhSn363?tk=R7OuWI5gCnd MF3543 「VXE蜻蜓R1鼠标游戏电竞长续航PAW3395无孔轻量化人体工学无线鼠标」
点击链接直接打开 或者 淘宝搜索直接打开
You need to open it in taobao app to see 89rmb
Does this mean cannot deliver to singapore?
Devilsire
bookmark for reference thanks for sharing, never heard of this mouse till now
am using ugreen cheapo mouse :o
gpgtmeowmeow
Btw, i saw in taobao got 2 sellers VXE and VGN. But former is cheaper and selling only mouse and dongle. Latter is selling mouse and some KB. I guess the VXE is more legit?
It really does not matter.
Spec sheets :
Check preferred switch
Check preferred sensor
Check preferred battery life
Check preferred weight
Check preferred size
Read reviews (can be fake):
Check multiple sources (TB, YouTube, Reddit, your friend beside you)
Check QC issues (can they be fixed easily diy?)
YouTube:
Unboxing
Form factor comparison of mice
Click test
Other things most YouTubers say are just opinions (aka can be nonsense). Take it with a grain of salt.
Physical store:
Test mouse form factor
Test mouse grip
Test mouse weight
Legit sit down and test on a mousepad
Don't buy from store if you like it (unless good price or you need it immediately)
Buy preferred mouse (if available from cheapest source). **** warranty.
Or just checkout straight without doing the above, $20-40 for a mouse can't be bad.
elmariachi
My mouse came liao, thanks for the recommendation. it really is a good mouse, super light and not bad
Np Bro! Enjoy your mouse in good health and just get better skates if you do not like the stock ones. They are kinda thin and will wear off quite fast. But pretty fast for stock skates.
liewhl
No Bro! Enjoy your mouse in good health and just get better skates if you do not like the stock ones. They are kinda thin and will wear off quite fast. But pretty fast for stock skates.
you got recommendation for that?
elmariachi
i use soft pads, coirsair cloth pad
My recommendation is go for Tiger Ice V2 but if you want something faster which I prefer using, go for Xraypad Jade skates. They are the fastest skates for cloth and very durable. Tiger Ice is slightly slower but I prefer the glide smoothness of Xraypad Jade skates. Comes 2 per pack. Tiger Ice only comes 1 per pack.
Just found this amazing item on AliExpress. Check it out!
SG$10.02 | Xraypad Jade skates for VGN/VXE Dragonfly R1 X-raypad VGN/VXE Dragonfly R1 Mouse Foot Sticker Feet
https://a.aliexpress.com/_oFErGsQ
liewhl
thanks bro.
daisuki
How 2 remove the existing pads on the mouse? i once removed my old pads and it left residue. when i paste back, the pads were bumpy :(
elmariachi
Remove the pads using a tweezer to lift up the edge and then pull slowly. Any residue to clean up can use alcohol swabs. If it's stubborn to remove, use a cotton bud and wd40 and apply it on the area and after 5 minutes use an alcohol swab to remove. Much easier this way.
Also, stay away from corepads. It's the absolute worst to remove the adhesive. It's like some bukkake freak show.
