looking for pc build - rtx 4070
NightRaven49
those are system pairing with 4090 test
now that u pointed it out, realised i forgot to mention that with a lower tier gpu, the difference would likely be even smaller, so i dont feel that premium for x3d is worth it for most people in sg.
Wondering if which model is a better choice? Or perhaps there are even other models I can consider?
Thank you!
Red words are those I am upgrading to.
MASTER MK3 | R5 7600 + RTX4070​
SGD $2,248.00 (price in inclusive of Windows 11 OEM)​
Specifications:
- IM76004070-WH20
- AMD RYZEN 5 7600 3.8GHz 6CORE/12THREAD
- ASUS TUF GAMING B650M-PLUS WIFI AX ARGB
- COOLER MASTER HYPER 212 SPECTRUM V3 ARGB
- KINGSTON FURY BEAST RGB 5600MHz 16GB(8GBx2) CL36 AMD EXPO
==> G.SKILL TRIDENT Z5 NEO RGB 6000MHZ 16GBX2 32GB CL32 (+$115)
- ASUS DUAL RTX4070 12GB GDDR6X
- WD BLACK SN770 1TB GEN4
==> SAMSUNG 980 PRO 2TB 7000MB/S GEN4 NVME M.2 (+$254)
- SILVERSTONE ET750 750W 80+ GOLD
==> ASUS ROG STRIX 750-750W GOLD FULLY MODULAR (+$70)
- COOLER MASTER CMP 320 CASING (3 ARGB FANS)
Original price = $1,660
Windows 11 = $149
Upgrades = $$439
Total = $ 2,248
SUPREME MK3 | I5-13400F + RTX4070​
SGD $2,253.00 (price in inclusive of Windows 11 OEM)​
Specifications:
- IS13400F4070-WH18
- INTEL I5-13400F 2.50GHz 20MB CACHE 6C/12THREAD
- MSI MAG B760 TOMAHAWK WIFI D5
- COOLER MASTER HYPER 212 HALO ARGB
- TEAM T-FORCE DELTA RGB DDR5 6000MHz 32GB(16GBx2)
- COOLER MASTER CMP520 ARGB BLACK MESH TEMPERED GLASS
Original price = $1,780
Windows 11 = $149
Upgrades = $324
Total = $ 2,253
id go with the ryzen system for this one, the 13400 is slower than the 7600 in gaming yet the overall build is more expensive. u also get am5 longevity, which makes generational upgrades possible opposed to lga1700 which is as good as eol at this point (14th gen likely only a refresh). personally id upgrade the ram, cooler and psu, the 2tb nvme addon and windows key better to ownself source and install (dynacore has 980pro non heatsink at 180). in fact for the addon nvme, if u r using it as a secondary drive rather than a boot drive, spending big bucks on a top tier one like the 980pro would be wasted, u will be served just as well with a basic but fast enough one like the adata legend 850 lite for less than half the invaderpc quoted price.
Yongkit
:ROFLMAO: 3080 once a top tier now lower its tier to mid range after 3 years.
I got the 5900x which is fairly competitve to 7700x in multicore benchmarks, but the experience in gaming still 5800x3D more pleasant surprised as I can really see the 1% pump up immediately.
another good things was my 5800x3D only up to 1.16v for gaming and the heat dump is also much cooler than 5900x 12 core cpu at 1.45v for that higher boost clock yet still unable to bring up the true potential of the 3080 in 1% low.
hiryu
@Fishbelly and @pearl_ml
Please note that before you upgrade the parts through Invader, have a look at online pricing and also SLS pricelists. In some cases, the upgrades costs way higher than the original cost of the upgraded part.
Example: One build originally had a case valued at $23X in SLS pricelist. When I wanted another case selling for half the price locally i.e $12X, the upcharge was $6X. The new case I wanted was something they have in stocks for other builds as well so I didn't understand why it costs me so much.
Overall there is some savings once you take the individual part cost in pricelists and add them up to compare against the pre-builts. However, the moment you want to upgrade here and there, that savings diminishes. In view of this, I have decided to build on my own even though I have never done one before.
pearl_ml
agree with this point. the default configuration offers the best deal.
hiryu
I would say best deal in terms of $ saved but not necessary in terms of full performance.
There are weak points right otherwise how will they earn $?
So typically they will provide a less than ideal PSU/MB/RAM etc. Headline will be the GPU/CPU front and big to attract buyers. If you are ok with it, yeah sure but must keep eyes open big big.
Once you go into quality of individual parts, then you will become like me. DIY and build haha.
pearl_ml
used to DIY and buy most parts from online platforms, except for the MB and CPU which i bought at SLS. the total savings were at most $200++ only.
cutthroat
The pricing of individual components can be further lowered especially if you're building a full system from the same vendor. For my case, Dynacore had the best prices and i was ready to buy from them but Nigel redirected me to TradePac who lowered the prices further for each component.
SLS was a funny experience for me. There are shops who don't have components you want on their pricelist but when you approach them they can magically procure it from other shops and hidden storages.
Koenig168
I won't be surprised if some of the SLS shops share inventory. Cut down a lot on costs.
Phen8210
yeah.. when u go there wan buy they say no stock.. then u say nvm next time... and suddenly they say wait.. and magic.
cutthroat
I got see people enquire about parts and ask for best price. They hear the quote they say nvm and wanna walk away then suddenly best price change become best best price. Funny la.
But i did encounter not being able to get the MSI 4090 Suprim X, Whole Sim Lim no stock according to the shops and on backorder since June.
TiryonFodrin
How come your pricing is so much higher than the same build TS quoted from invader?? What is the pricing without windows 11 key?
On another note, your upgrades are good choices. If I may add, ask them to change the cpu cooler as well. Thermalright PA120 SE/non-SE and PS120 SE is pretty much unbeatable in terms of value/performance right now
Hey TS, I was also considering both of these!
Just wondering, from all the advices, which model, upgrades and pricing did you went with?
