Loud Fan Noise
ykrap1
Get corsair SP series for heat dissipate from heatsinks or radiators
And AF series for casing fan
shadow84
I think you use the wrong fans
http://www.corsair.com/en/air-series-sp120-high-performance-edition-high-static-pressure-120mm-fan
My fren using the high performance edition and he complained that even if its pwm, still loud.
Urs is china knockoff?
twlee88
Guys, have a look.. its running at 4krpm :eek: is it normal?
any other anomalies based on this?
and just now i go into bios..the fan level is 9...what is the appropriate fan level?
shadow84
You have something else plugged into ur cpu fan header. What is it? It shld be the 2393rpm de.
shadow84
something plugged? huh? just 3 fan. 1 cpu, 1 at the back computer and 1 comes together with gpu
As in what else is plugged into ur cpu fan headers? I see to 2 rpms registered. The 4k rpm might be ur AIO?
So, can presume ur rear fan is SP120? Whats on ur CPU?
Alternative X
Dude, he is using the stock Acer Predator casing with only 1X 92mm fan. The only fans are probably just the CPU cooler fan and the 92mm fan. There is no way an AIO is going in there unless the AIO has a 92mm rad.
shadow84
Paiseh, missed out that.. Then, the 4k rpm belongs to the 92mm fan bah.
twlee88
Sorry to disspoint you shadow..:(. what is AIO and SP120.
The thing is, i plugged my CPU fan to MoBo CPU_Fan 1 and the fan behind my rig to PWR_Fan1
Jian19
When u transfer ur CPU to new mobo ur stock fan thermal paste got wipe off and reapply Bo
shadow84
Nvm, tot u gt AIO and SP120..
Well, if u only gt stock cpu cooler and 92mm fan, then dun expect wonders bah. That cpu cooler is designed to give u some cooling nia, but not as effective as branded coolers.
As for the 92mm, it could be a cost saving move to reduce footprint of ur case. Even at max speed, cant feel much de.
