erwinrommel
- Sep 30, 2007
What video player is good for mac? Quicktime still cannot play H265 video.
M-Player X or VLC media player for me.
Odd rite. Im guessing if u use it for basic stuff its ok unless u do all the complex stuff.I'm using Office for Mac 2011 as well but it works fine with High Sierra.
So many problems don’t dare to update. Read online bootcamp dies after updated.
Parallel also die unless buy new version.
my mbp 15 2017 with bootcamp + parallels working after update
Need some expert advise. After updating to High Sierra, the time in date and time settings always revert back to the original time, even when the 'Set date and time automatically' is unchecked. Usually I'll always set to to 5mins faster and every time I start up my MBP, it reverts back to the original time.
In Sierra, this doesn't happen. Any issues whatsoever or is it a bug?![]()
You need to reset nvram. Reset smc only if u have trouble with lights or hardware.
Usually ill recommend both..
The loginwindow process crashed few times which seem to cause my login session terminated, i.e. back to login screen, can’t use touchID/Watch unlock
Not sure of the pattern yet. I enable the diagnostic reporting to Apple after 2x...
I’m using 15” TB MBP2016
How do I do that? Will it erase my current settings and storage inside?
