qwerty_hippo
- Oct 9, 2007
Booking sbf is as good as giving up the change.
only 1-3 flats for Chinese
https://www.hdb.gov.sg/residential/...cess/manage-my-application/application-statusHow you see the number of applicants ar? The new website UI really suck ass.
Singles 10charHi guys, need some advice : if a single who has never bought any subsidized flat from HDB apply for the SBF. Under the application rate in the HDB web, he would be classified under 1st timer or single. There are 3 columns in the Non Elderly column - 1st timer, 2nd timer and singles. Confusing
| Bedok | 3-room | 16 | 64 | 1.9 | NA | 4.0 |
| 4-room | 14 | 221 | 9.7 | NA | 15.8 | |
| 5-room / Executive | 6 | 86 | 8.8 | NA | 14.3 |
use the map on the right and zoom in for the exact location. I saw 9 on the map.Where The hougang sbf exact location?
Ok now i saw the list. It is buangkok woods for 2 room flexi.use the map on the right and zoom in for the exact location. I saw 9 on the map.
https://homes.hdb.gov.sg/home/finding-a-flat?modeOfSale=SBF
still thereWhat happened to the kallang residences project? It was there since the launch of SBF may 2021, but today when i check, it says "This project is no longer available". Means what ah? Bug ? or the house owners suddenly took back their house from hdb because they decided they want it/can afford to pay for it ?
3-4 room is 99 years lease while 2 rooms have a range to choose from. usually shows when that block have 2/3/4 rooms to choose from.when they say 15-99 remaining lease means what?
I believe this mean, there are too few flats to be considered for second timers.When it shows "NA" (under 2nd timer), does it just means no 2nd timer has applied so far ?
For example Bedok..
Bedok 3-room 16 64 1.9 NA 4.0 4-room 14 221 9.7 NA 15.8 5-room / Executive 6 86 8.8 NA 14.3
Booking sbf is as good as donating $10 to hdb.Booking sbf is as good as giving up the change.
Then 4room 15.8 means got 15.8 times of people apply?I believe this mean, there are too few flats to be considered for second timers.
Yes, 15.8 times the number of flats available.Then 4room 15.8 means got 15.8 times of people apply?
Got a question about sengkang sbf.Yes, 15.8 times the number of flats available.
