MBP accessories
rayban
Bro how many charge you can use for yr xiaomi power bank. I asking a Friend get for me while he at Shenzhen. Though I have a rav power 26800 one already. Get one for wireless charging lol
So so only I think.
Get 13.5 inch one min. Unless they write compatible with MacBook Pro cause MB pro is 13.3 inch
inxoxni
Proximus
Hmm then what u recommend? Those hard cover with ventilation?
For my MacBook, used Dbrand’s skins. I have tried those covers before and it added bulk to the slim profile of MacBook.
Proximus
Is skin easy to paste?
The skin have to be pasted on the base of the laptop?
No difficult if you follow their video instruction. Yes the skins are available for top, bottom and touch pad
ksksksks
Your Ravpower can only do 30w would be quite slow.
I can get almost one full charge but I also use concurrently with other devices.
d3n
My hootoo usb c hub is here! Quite compact.
And it lights up too!
inxoxni
Then don’t use anything?
Hmm will have air bubbles?šŸ˜…
Only scare later tear off sticker... will have residues
I bought a macbook pro Touch Bar 15 inch late last year and bought those hard cover on shopee. I had to modify (cut off the side) to allow the usb c hub to fit. I brought my macbook to Brisbane in March 2019 and realised that the case makes the computer bigger and heavier. I also realised that during transportation, my macbook will be in my padded bag. Then it came to me that I do not need that much protection and decided to go for sticker (front and back) for scratch protection. I also bought it from shopee.
Yes, it is not as easy to apply. I peel a bit of the sticker and stick, remove to align a few times, peeling more each time before fully applying. Because it is opaque so remove and re-applying is ok. If I see bubble, I will peel back to remove the bubble (not fully because not easy to align again) and stick again.
I got the same colour as my macbook pro (space grey) and also got the palm protector. So far I am happy with them.
I also got those silicon keyboard cover. yes it is not as good to type but I think the difficult not that great. If you are not sure, I suggest getting the cheapest one (transparent one) you can find on shopee or taobao (if you are familiar with taobao), if don't like than don't use also ok.
I did thought of getting those sticker to protect the Touch Bar but I do not think it is very necessary as compared the keyboard cover as my fingernails do not scratch/touch/hit the Touch Bar as much compare to the keyboard.
This is my usage with my macbook but does not mean that it applies to you all, please think through your use case, for example a shock resistant case (like those from UAG, not cheap) if you carry your macbook only (not need a padded bag) frequently outside and use it on any surface you can find.
inxoxni
things I have bought for my macbook pro
just for sharing the stuff I have gotten for my computer:
Hard cover (no longer using)
https://shopee.sg/product/86634598/1449973261
USB Hub (a little warm when using but I do not think it is too hot to touch. If i know Ugreen has a similar one I would have gotten it, as I think ugreen quality not bad)
https://shopee.sg/product/86634598/1483807840
Keyboard cover
https://shopee.sg/product/86634598/1484479860
Front (top) and back(bottom) sticker
https://shopee.sg/product/108157503/1708420459
Palm rest and trackpad protector
https://shopee.sg/product/108157503/1876218897
stand or feet (no longer using as I bought the next item)
https://shopee.sg/product/90339629/1856956228
Another stand (I think it is a imitation from a kickstarter)
https://shopee.sg/product/48834674/1941347129
Another usb hub (for using on recently bought Surface Go which also can use for macbook)
https://shopee.sg/product/64922680/1148147510
I also have xiaomi usb c power adapter (went to shop to buy at i think $25, came with a usb c to usb c cable too, same as this)
https://shopee.sg/Cable-USB-C-to-US...wer-Adapter-Charger-45W-i.46313738.1828113070
ZMI powerbank 20000mah version bought for use with nintendo switch (can also charge macbook, bought from qoo10 but similar to this one)
https://shopee.sg/Xiaomi-ZMI-15000-...erbank-Quick-Charge-3.0-i.20595563.1057256946
For the last 2 items, i would suggest these 2 replacement instead:
power adapter:
Just saw this with 2 usb A and a usb C (usb c up to 45w)
https://shopee.sg/Tsmā˜…XIAOMI-ZMI-HA...-Huawei-MacBook-Fast-T-i.133316305.2198170861
A new version from the 45w I have but 65w, means can charge faster
https://shopee.sg/Original-Xiaomi-65W-USB-Type-C-Power-Adapter-Wall-Charger-i.67017280.1460711304
Powerbank:
https://shopee.sg/XIaomi-Power-Bank-Gen-3-Pro-Laptop's-External-Battery-i.11050324.2541139059
Disclaimer:I do not guarantee the reliability for this links have posted here, do not blame me if the product spoils or the seller runs away with your money. However, I thinks shopee will only release the funds to the seller if you confirm receipt so should be quite safe. I also don't know if the links I posted is the cheapest or best deal, please do your own searches in lazada, shopee or qoo10.
inxoxni
No bubbles lah.... it is not screen protector.
They will not leave residue, i have removed mine after 1 year to change to another design. :D
I think good brand sticker like dbrand usually no residue (not cheap), they are usually easier to apply too. Even if got residue, should be able to remove with some solvent like lighter fluid or goo gone as the surface is aluminium and not much/no opening that the fluid can slip in.
Just a tip, if the sticker is folded and got crease, can try using a hair dryer to heat a little to soften the sticker, might be able to remove or reduce the visibility of the crease line. Can do the same let the sticker to soften (press down firmly after heating) for rounded edges.
Proximus
Just seen the skin design looks nice leh!
Yes, they have a wide range of skins. Am using the black dragon skin. I prefer something subtle and this skin have more grip compared to the rest - I have sweaty hands....
