Michelin PS4
EJB
Cannot, jin emo liao, always get targetted, I go draw emo circles.
networked
i always overpumped my by 20-30 at 240 kpa for R16 sedan to compensate for air lost. no big deals. plus i prefer more solid feel.
when i did svn at AD, they pumped even higher. machiam feel like driving lorry.
mewmart
For me 225/45/R17 about 36PSI would be more suitable, balance of grip and comfort.
keenklee
IMHO.
If you are ok with about 6% decrease in the contact patch size.
Daty41
at petrol station always pump a bit extra cause the temp is high, pressure will read higher...and many ppl pump when going home (after a long ride) if u really want to pump when cold, get a portable pump and pump the tyres after parking overnight.
EJB
As long as within 5km like at 5am in the morning, the tyres won't warm up that much. My house to Esso is only 2.6km. No need get portable pump.
how to overpump...once they ding won't lip liao rite
ItsmeagainhK
Im on 195/50/16. Over 2 inch over stock wheels.
Front 38 psi cold
Rear 36 psi cold
i got portable xiaomi airpump so every 2 weeks in the morning will just check and top up as needed.
keenklee
IMHO.
Actually pump tyre with compensation when they are hot is a more accurate method as they will be equal all around.
sinistral
IMHO.
I disagree.
Rear tyres may not be as 'hot' as the front tyres after driving around some time on a hot sunny day. Likely explanation is that the front brakes do most of the braking work, so heat dissipation at the front brakes are higher compared to the rear, so the front tyres tend to be slightly higher in temperature.
That is why the recommendation is to pump when the tyres are cold, where the tyres have the same temperature as the ambient temperature.
