- Dec 15, 2012
Sp4 got fan right?
Except for the Core m3 variant,
the others have fans!
Sp4 got fan right?
A surface tablet is excellent for the other things that you listed but is really not designed for gaming.
It can game, but it depends on what games you would be gaming on, how many frames you are looking at as well as what gaming settings they are on.
Being a fanless, passively cooled system in a very thin frame, do expect certain thermal trottle - which is the reduction in your CPU speeds - to reduce heat.
Hope this helps you out.
Thank you for the information.
My game are those very light like puzzle game, not those racing or FPG games.
But, not sure to wait for Surface Pro (learned better battery life) or go for the discounted Surface Pro 4
Anyone can recommend which shop is having the best deal on the current Surface Pro 4 model? Thanks![]()
IMO sounds like you're not a heavy user so if you want to save, may as well... unless you want the fanless i5 with better battery?
I thought Intel i5 CPU required cooling fan inside Surface Pro 4?
Please correct me if I am wrong.![]()
Jace was referring to the New Surface Pro ( let's just call it the "Pro 5" for now to prevent confusion)
Pro 5 is passively cooled for their i5 variants .. pretty innovative![]()
Looking for a tablet PC, should I wait for new Surface Pro or go for the current Surface Pro 4 with price reduction.
General usage like office productivity and note taking plus small light gaming and watching movies during traveling. I am looking at the lower end series the m3 CPU.
anyone has or play with surface laptop before. How is it?
I using SP4 now but realised I don't really use the pen much actually and the form factor of traditional laptop seems to be more convenient. Not sure should go back to laptop like surface laptop or xps13 anot.
any one faces the problem of the sp4 type cover not working after windows update?
Tried googling, most solution is to press power + volume up for 30 secs. That doesnt help in kicking start my type cover
