mid-high end gaming rig advice
Goodshot
i'm a nvidia fanboy, never try AMD before
Amd is cheaper / sharper image / and quite fast(R9 280x above) .But i personlly feel nvidia card is more stable , anyway both are diff architecture. Hard to say
MoneyFace =p
Im assuming i5 4660 is a typo for 4460. Please dont get the 4460. It is already currently cutting close to being/already is a cpu bottleneck. Somemore you wanna upgrade your gpu in the future. I can only recommend a 4460 if u intend to stick to a current gen mid-upper range gpu and not upgrade gpu alone (aka upgrade entire system together).
You will also face a dead cpu upgrade path with lga 1150. Broadwell desktop is likely to be a disappointment, and skylake is coming shortly after. Go for the tock rather than the tick.
The 4460 at its low clock speed is no more powerful than my 4ghz 2500k. Paired with a gtx970, all i can say is that i sometimes have to ramp my clock to 4.5ghz to alleviate some bottleneck situations. Some games that come to mind include ACU, sleeping dogs..
I recommend nothing less than a 4690k paired with a mid range z97. Preferably a 4790k if u can. I regretted getting the 2500k 3.5years ago, should have forked out a little more to get the 2600k. Thats my personal opinion. Consider with caution.
Cheers.
:s22:
You got any idea what you talking about.
Sent from microwave oven using GAGT
Probably placebo effect on him....
Overclocked i5-2500K vs Haswell i5-4430 on R9-280X no apparent improvement on gaming:
Plus CPU scaling on Titan X/GTX 980 with various clocks on Haswell also don't show any much difference:
So CPU bottleneck is much less of a possible issue with current and near future high-end cards on a clock-locked Core i5-4460
MoneyFace =p
MOBO+CPU: MSI H97 GAMING 3 + i5 4660
RAM:CORSAIR VENGENCE PRO 1600MHz 8GB
SSD: SAMSUNG 250GB 850 EVO
HDD: WD 1TB BLUE
GPU: MSI GTX970 TWIN FROZR GAMING
PSU: SUPER FLOWER LEADEX GOLD 650W
CASING: Fractal Design R5 Titanium Window
Monitor : DELL U2515H 2560X1440P
initially I plan for GTX980Ti, but I decide cut back some budget for my holiday travel. but i will upgrade to GTX980Ti or TITAN X by early next year. but not sure 650W PSU enough for TITAN X or not? do i need a more powerful PSU?
welcome all idea and thanks!
No need to upgrade later you can just afford to hoot them now. :)
Cool black and green theme with green LED glow on the graphics card cooler. :D
CPU+MB: Intel Core i5-4460 + ASRock B85M Pro4 @ $327
RAM: Crucial DDR3-1600 CL11 8GB @ $67
GPU: Zotac GTX 980 Ti 6GB @ $1019^ (Lazada Singapore)
SSD: Samsung SSD 850 EVO 250GB @ $159 (Qoo10)
HDD: Western Digital Blue 1TB @ $69
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Leadex Gold 650W [80 Plus Gold] @ $129* (Lazada Singapore)
Total: $1791
Buy others from Tradepac, #05-18.
^Price after Lazada CITIbank weekend 15% discount (Capped at $30)
*Price after Lazada EZBack2shopSG53js94 $20 discount coupon ($60 minimum spending)
OR
Hot black and red ASUS ROG-like theme with red LED glow on the graphics card cooler. :evil:
CPU+MB: Intel Core i5-4460 + ASRock Fatal1ty B85 Killer @ $342
RAM: Kingston Fury DDR3-1866 CL11 8GB Dual Channel Kit [Red] @ $99
GPU: Sapphire R9 Fury X 4GB @ $999
Total: $1818
localITguy
Suspended
and EXPENSIVE, i poor . only can go with amd:(
laccas
Total: $1791
OR
Total: $1818
thanks bro
superzheny
:s22:
Yes i do. From personal experience from my limited available hardware and google.
https://www.youtube.com/watch?v=Rutk9ErhKG4
Watch the region in the towns.
http://www.techspot.com/review/991-gta-5-pc-benchmarks/page6.html
Further more the above benchmark was done at 1600p. If op plays at 1080p even more cpu bound.
Of course anyone can produce a game which is more gpu than cpu bound. But please. You are buying a 980ti. Dont skim on cpu
monikernemo
Hyperthreading offers little advantage for games. If the user does not intend to OC, there is little advantage for getting a unlocked CPU.
Frame rate plateaus around 3.5GHz, and 4460 at 3.2GHz is half way the last significant jump in fps from 3GHz to 3.5 GHz, makes it a optimal CPU choice.
A build is more needs oriented rather than balance oriented. If user has no such needs, ultimately a waste of money.
DoUevenLift?
i5 4460 Asrock H97M Pro4
kingston 8gb 1600mhz
western digital 1tb blue
transcend 256gb ssd
sapphire r9 280
silverstone 500w 80+
use for some gaming, wont be playing those high end games though.
1) is i5 and h97 board necessary or should i downgrade?
2) whats the difference with western digital green and blue? i thought of getting 2tb but i see most people get blue which only has 1tb.
3)any better/cheaper psu? i randomly selected a 500w 80+ as i have no idea whats good
laccas
iwill go down to sls this to DIY my game rig finally.got some qustions to ask experts here. thanks
1. is MSI H97 GAMING 3 mobo only support RAM up to 1600MHz? if I plug 2x4GB 1866MHz RAM, it will be no issue but capped at 1600MHZ? am i right?
2. if i only buy mobo+cpu, HDD and GPU at Tradepac. do they charge me more than the price on their pricelist?
3. is the thermal paste necessary for CPU?
monikernemo
1)
Should run at 1600mhz, just buy 1600mhz anyway.
3)thermal paste is necessary if not your CPU will fry and gg.com.
Thermal paste fills up the air gaps between your heat sink and ihs of your CPU. Thermal paste ensures proper contact to heatsink and having a higher thermal conductivity than air, allows the heat sink to cool CPU properly.
ahjunz
Total: $1791
Maybe just get with Palit 980ti SJS, the white on the GPU complements the white on the R5. Using the lazada discounts probably getting it at $950-$970? (plus if you got shopback/FRANK etc)
Jian19
if u using stock hsf they aready preapply thermal paste on it. if u using aftermarket cooler they will most likely provide a tube for u to apply
laccas
Thanks bro. because I bought the wrong RAM from lazada, i should buy 1600 instead of 1866. only Z mobo can oc the RAM, but no point for me to buy a Z mobo just for the 1866 RAM, I will use it like 1600. bit wasted.
laccas
thanks bro. one more question. the thermal paste can last how long? do i have to re-apply it after some time?
monikernemo
2-3 years just reapply should be no problem.
When reseating heat sink also advisable to wipe off old one using isopropyl alcohol then reapply. Isopropyl alcohol is readily available in pharmacies, known as rubbing alcohol.
MoneyFace =p
That choice was made cos Palit card only released last friday... Yes please go for Palit for now.
MoneyFace =p
Only small difference in price...
laccas
any one know SLS got any shop selling portable/foldable trolley or not?
