[Mini-Review] Watercooling Setup!
ra[g]e
I DIDN'T HOOT THAT 480! =:p
Maybe my next upgrade post-wc would be get a bigger case (corsair 800d still got stock?) and hoot 480 or even 600 or 720 or something like that
lagi best just put radiator into fish pond :s13::s13::s13:
OT: Post #200 :)
Woohoo do update us :)
ra[g]e
Teaser pics of WC update :D full review coming soon...
EK Supreme HF blue replacement top with the mobo NB block
Mobo SB block
EK D5 pump top replacement
Graphics Card
ra[g]e
Haha, what was the previous 4.0Ghz load temp u had on the first WC?
OCCT load was 59 degs, linpack hit near 70 degs tho... 1.35 vcore sucks :(
At like 1.3 vcore temps dropped by more than 5 degs but not stable... oh well.
repel89
Thats much cooler then mine le. Haha, mine OCCT w/o aircon is like 62-64 degrees. With aircon then can fight with urs :s13::s13:
Tried enabling the "Normal" option in Vcore. Works for me :s8:
zedane
Eh the EK pump top for improving flow rate? Is it worth the money getting it? :o
BTW love the new top for ur supreme HF :D
ra[g]e
The EK pump top is mainly so that I can use compression fittings on the pump for the smaller tubes, and it also allows me to have inlet/outlet facing the same direction for better routing...
Flow rate is better as well :D
ra[g]e
wow! very nice. make me want to go for water cooling too
Actually you can consider ler... at least for cpu cooling... get a T-line for easy coolant draining when you upgrade your proc... or make the tubes near the cpu loose...
Or you can have a separate wc rig which you don't change much with all the full kickass waterblocks on everything :D
hiroko_21
bro.. get another rad is a good idea.. separate your gpu and cpu cooling.. later on i'm setting up my wc rig le..
i also need to thanks sabe for all his wc stuff.. great stuff @ good price. :s12:
ra[g]e
Just set up the 2nd 360 rad with the new mobo block... idle temps @ 33 degs on a hot day :eek:
