I thought you were going to join me leSleeving is addictive
Dun poison me with water-cooling. A walk around SLS with so many V6 GT is enough poison![]()
), the only cooling I've done so far was air-cooling.Hey,Hey ra[g]e,
I've a question with the fittings and tubings for my future water-cooling system.
I'm planning a CPU + GFX loop. I need two fittings for each WB and according to EK, the EK-BAY SPIN Reservoir requires fittings. Does the MCP655 require fittings as well? What about the EK RAD-XT 360? To be honest, I've never even touched a water-cooling system before (except in fish ponds), the only cooling I've done so far was air-cooling.
I was thinking of getting a 1/2'' fitting, but is a 3/8'' internal diameter, 1/2'' external diameter tubing compatible with this fitting? And if I get a 1/2'' fitting with 1/2'' internal diameter tubing, do I require tubing constrictors?
Thanks.
I thought you were going to join me le![]()
Hey,
You'll need two fittings per radiator as well. MCP655 is not compatible with compression fittings, but you should worm clamp the tubes once you get it in. You can get the replacement top for the MCP655 if you wish to use compression fittings on it.
1/2" compression fittings fit 1/2" internal diameter tubes. 3/8" fittings fit 3/8" internal diameter tubes.
Also, the MCP655 requires tubings with 1/2" internal diameter.
That EK High Flow Fitting is actually a barb, to be used with clamps... it is not a compression fitting.The fitting I was looking at is the EK 1/2'' High Flow Fitting.
http://www.edge2o.com/store/product_info.php?cPath=18&products_id=146
So, to summarise, the CPU block, GFX block, reservoir and radiator require fittings. The MCP655 does not support fittings, but instead worm clamps are more suitable. 1/2'' fittings do not fit in 3/8'' internal diameter tubes.
So 8 fittings in all, I suppose.
Thanks.
Easier if you use compression fittings... yes from your setup 8 fittings seems right.
whoops!
Yep compression fittings do not need clampswhoops!
Compression fittings would not necessitate the use of clamps, I take it?
Thanks.
Try Gary @ UVnium
If no stock can order from Edwin @ Sgmodder...
Haha thanks ra[g]e for the advice.
thinking of going down to SLS hoot the K62 and core parts first.... your WC setup beri beri tempteeng rehhx
But must wait for moolah come in first then hoot second batch![]()
Haha, tempted leh. But i change hardware quite often also
Next time must learn Water Cooling from u le![]()
WelcomeGotcha bro... will give it a look the next time I'm there.
Thanks!![]()
Haha no probs man... WC really rocksHaha thanks ra[g]e for the advice.
Wah so humble
Nvm got chance can help others set up ma![]()
Wah so humble
Haha, dun think i will help people ba.
Maybe for a small fee i guess![]()
Woo... congrats!Hey ra[g]e,
quad 120mm rads anyone?
http://www.edge2o.com/store/product_info.php?products_id=158
and i just hooted my rig. not wc yet, but it looks great.
thanks for the suggestions![]()
Woo... congrats!
Get your wc and post pics soon... hehe
See if you can find a place to put that 480 rad...![]()
