MITX desktop recommendation :)
Vadher
Nope. If just as an entertainment HTPC for movies, it's fine. But I don't think you can play game on it though.
But, if you want, build yourself is cheaper. Getting Aftershock is only for its warranty and services. Their pc is generally more expensive than a DIY of the same thing.
Sent from Overpowered Phone Mark III using GAGT
Thanks. I can't play games on it is because of my TV? I'm sure the 1050TI should be fairly sufficient for some games.
singupingu
GTX 1050ti is not powerful enough for 4K UHD gaming. Unless you do it at 1080p and upscale to 4k. Still, the detail still need to be lower to achieve 45 fps and above.
You may be fine with simple classic games. I'm not too sure how well will it fare with modern titles. For my knowledge, gtx 1050 ti can play on med-high settings for 1080p for modern titles (not inclusive of AAA titles)
