how many u bought? why tempered glass at USD320? i bought at USD340 for tempered.
The non tempered is at USD320 wor~
Bought 2 sets. offered red-cap usd300 for each.. he countered with usd320. true story.
Tempered is ok but I didn't choose cos I redid review dust will get in and I'll hav prob removing them so I took w/o tempered
What's tests uve done to ensure flawless screen quality?Bought 2 sets. offered red-cap usd300 for each.. he countered with usd320. true story.
Besides the dead pixel 3.0 any other test can be carried out to check for ghosting n backlight bleeding. Thksdid that dead pixel 3.0 test... no dead/stuck pixels.. might have some back light bleeding actually,. but not too sure if its just cos its glossy... and large.. so sometimes the edges doesn't look as black as the center.. no issues when running movies/games tho
YEs it does come with cable. I'm on the 7870
Hi anyon can help the crossover only got 3 buttons at the back right I tried to display out but the side jus turned red color and nothing happened. Am connecting with my MacBook air. Anyone can help me?
Has anyone use this with a MacBook air before via a mini display port to dual link dvi adapter ? Is it supported.? Thanks
yes i am using it now. It is supported.
However, the dual link dvi adapter is extremely unreliable. Sometimes must unplug and plug back a few times to get proper signal. Lots of people having the same problem too.
the adapter has 3 different firmwares. The latest is 1.03. Hopefully you get the latest one when you buy.
Hi,
You are running dual 27Q on your 7870? Do you play games?
I asked him for perfect pixel guarantee but he say cannot. Haha.
I asked him an hour ago. For crossover tempered panel.
guys i guess i have to sell off this baby as i cant spend another $159 on the adapter. ive only my macbook air for work and play. i dont use a PC. anyways price fixed at $400. fyi i paid more than this, bought alot of wrong adapter and cablesand collected it yesterday only. keen pm me thanks.
wont go any lower so dont bother asking for discount.
crossover 27Q
self collect. first come first serve
