i just got the screen too and it looks great!
now guys, how do I utilise this screen properly?
any tips?
seems to me best is to arrange windows side by side?
anyone can comment on this monitor vs samsung PLS monitor?
I have the Samsung pls monitor. It's great and loving it but I am now considering getting another one or two more to with do dual or triple setup but if I get the samsung one it will be 1800 and crossover will be a lot cheaper. I think for this monitor it's cheap and good but got risk....
thanks.. thinking of getting samsung one from all the reviews i read and watched.
1 samsung pls can get 2 korean ips monitor. Using my korean monitor for almost half a year already. No signs of it going any time soon. The price traded for warranty, hmm...
By the time the korean monitor goes probably PLS technology will be much cheaper.
How much does the Samsung 27" 850 Series cost in Singapore?
I am running dual 27Q.
The screen on the right side may black out once in a while and then come back on. I reckon that it could be my gfx card that is being overloaded.
When the screen goes blank ... does it come back on or it stays blank? If it does, how long does it stay blank?
The bad thing about it is the 2 pin plug, filmsy and sensitive. The screen still goes off sometimes when i accidentally touch the wire.I bought mine last year during IT Show (nov one) at $849 + free printer.
Now its retailing at $879 lowest....
actually it all depends on which korean panel u getting. the one i want to get is Pivot + DP + HDMI ports and its close to $630 including 7% GST if tio....
But of course if you compare to a 27Q which is around 380 - 399 there is a big diff.
I troubleshoot over the net. Found out that it was a lack of power supply. I changed the extension cord and everything was ok already.The bad thing about it is the 2 pin plug, filmsy and sensitive. The screen still goes off sometimes when i accidentally touch the wire.
just buy a crossover model. u wont look back
solid stand and frame.. a fan will make monitors with plastic stand wobble
