[Monitor] Crossover IPS LCD 27 inches
Ultrafire
Yes it's burnt, that mosfet in the first picture on top of "TO AD Board" connecter.
If I remember correctly i1magic have some extras if you can solder them yourself, you can try and PM him.
Or try Sim Lim Tower? Not sure if they have this. Mine has the same issue too, I asked the seller to send me a replacement LED driver board.
sorry for sounding noob , but how you know its burnt ah ? looks normal leh :s13::s13:
i found this at ebay, but somehow looks different leh
http://www.ebay.com.sg/itm/Video-dr...740?pt=LH_DefaultDomain_0&hash=item1a028e8aac
how much did your seller sell you the board for? my crossover bought so long ago i cant remember who i bought from already
eliteFX
Your 3rd picture shows it's burnt isn't it? :s22:
This is the next rev board that doesn't have this issue.
Check with i1magic for the parts, he mentioned it a few posts back. Solder the mosfet yourself, save some money :o
Mine was still under 1 year warranty so the seller shipped it for free.
Ultrafire
i bu zhi dao ma , electronic idiot
wa , need to go dig out my solder gun :s22::s22: thanks much
crashed
seems like the popular seller for Crossover panels on Qoo10 is gone. Anyone knows who is a reputable seller to purchase from? Hmm..
In summary can I say that the quality of Crossover is better than Qnix?
LegendZenify
Currently, yes.
The Qnix QX2710 currently is a much inferior version of the monitor that used to be highly recommended.
It uses a (subjectively) inferior PLS panel, and they switched to PWM dimming for the backlight (info on PWM-dimming & its side effects - http://www.tftcentral.co.uk/articles/pulse_width_modulation.htm)
Currently, the highly recommended monitor over at overclock.net is the Crossover 2795QHD -
http://www.overclock.net/t/1555354/...licker-free-overclock-able-matte-1440p-ah-ips
crashed
Currently, yes.
thanks for the explanation.
to be honest, i don't even game but i want a 27" screen in 1440p (read that 1080p on 27" is pretty terrible upclose) that I can surf net and watch my shows on. that's about it, so i don't really bother about overclocking, etc. given my intended usage, a Dell u2715h is quite a lot of money to pay for something that I'm gonna "under utilise". any recommendations? oh and vesa mounting is a must.
LegendZenify
Tbh, I don't think surfing net & watching shows is under-utilizing a monitor.
Do also consider that Dell offers 5 years onsite warranty, while the korean panels only have 1 year warranty (and require you to ship them back for warranty claims)
Do also note that while these monitors all support VESA mounting, the korean monitors will have half of the stand attached to the bezel (you may have to debezel these to remove it)
The prices of the various monitors you mentioned are below, for comparison:
Qnix qx2710 ~ $300-400
Crossover 2795QHD ~ $500
Dell U2715H ~ $700 (depends on discounts and promos)
The main factor is the warranty, and if you are comfortable with shipping stuff back for warranty, etc.
Otherwise, the Dell U2715H would be the better choice for your peace of mind, superior panel quality, and to avoid the hassle in the case of monitor failure.
Your choice.
The_King
currently using a dell 23inch lcd (about 7 years old) reason is i want a bigger screen
look for a lcd for video or sometime gaming and looking for a lcd that can last
how lasting is the qnix?
this is my few choice
QX2710 LED Evolution ll Adobe DP Perfect Pixel
QX2710 LED Evolution ll DPmulti True10 PIVOT
Dell U2713H
samsung 31.5" SE590C
i1magic
Your choice.
I agree with you. Basically, when we are paying more, we are paying for the additional specs + warranty.
I actually ordered 2 x CrossOver 27Q with stand on 21 May 2012. On around Jan 2014 (about 1yrs 7mths after), one of the monitor starts flickering and eventually the screen blacked-out.
After some research, open up the monitor and found out that the LED driver board has a chip that is toasted. Contacted the seller and asked for a replacement LED driver board. Cost me about SGD$60.
They sent it over to me. I opened up the monitor, replaced the LED driver board and *finger crossed* the monitor has been serving me well since.
crashed
Your choice.
I think your explanation makes it pretty clear. The five year warranty does give me a peace of mind, and seeing how Korean panels are a hit or miss thing (even brand new out of the box), I think going with Dell would make it relatively hassle free. My Samsung 2333SW has been going strong (although it's starting to dim) for the past 6 years so I would rather spend a bit more to have something that will last a good 5 years or more.
Cheers!
LegendZenify
Cheers!
Glad I could help!
The_King
@crashed
are you getting the Dell U2715H?
i was thinking about choosing this also
crashed
@crashed
Planning to. But the price tag ($799 before any promo) is making me think twice.. :s13: I even bought a Loctek monitor arm from Taobao.. but have not placed an order for the monitor.
31.5" is way too huge for desk placement. :s22:
Swiftbladez
31" too large? Nah, using 40" and its more than fine :)
The_King
thanks for the reply.
currently using a dell s2309W brought 6 to 7 year ago.
my table is about 1.7m
it should be enough for me
ss is using VA panel and dell AH ips
maybe i should go take a look at both set
mosmos
High Honorary Member
:s22: why not just get a 32" TV, it should be much cheaper with decent resolution~
The_King
quick update.
Just look at the 23 lcd (cause mine 23")and 27 lcd
it look like there not much different.
maybe i should get the samsung 31.5inch lcd
The_King
@crashed.
there many model for Loctek monitor arm.
mind telling the model you brought?
thanks a lot
crashed
Loctek D5UH, the one that comes with two USB ports at the base.
Bought from Taobao, with shipping ~SGD90. Seems to be taking some time to arrive in SG though.
