Motherboard and gpu problem ?
Hulky768
Hi there. Recently bought a asrock h87m pro 4 and jus slot my hd7850 into pcie 3.0 slot, however gpuz show it is pci-e3.0x16@ x16 1.1. note that my motherboard is a pcie 3.0. Would appreciate advice on this.
shadow84
Did you update your mobo with their drivers/utilities?
Mine also just showed 1.1 ... it was 3.0 when i read ur msg... Try running a game or benchmark and see if it increases...
MacClipper
Prob. power saving feature kicking in.
In GPU-Z, click on the little question mark icon on the right border besides the Bus Interface wordings and run the stress test in the pop up box and now check the version newly reported.
Hulky768
Tried the render test, when i exited it after 15mins, it went back to 1.1 again, have updated every drivers using the cd provided by the asrock. One thing weird is that, when i'm usin my amd catalyst manager, it shows that the gpu is at pcie 3.0, while gpuz provided diff results :/
Hulky768
At firs gpuz show it is at pcie 2.0, den i itchy hand go start render test and now its stay put at 1.1, dk what to do next...
jaykay11
When power saving, mine is PCI-E 3.0 X 16 @16 1.1. Activating the render test brings it to @16 3.0. Stopping the test brings it back to @16 1.1. You might want to try reseating your card. Sometimes i get @8 1.1 after cleaning and putting back my PC together, reseating it solves the problem
Hulky768
Hmm thanks for the advice, would try it. But may i know if ur usual days of usin the com, the card still stay at 1.1 right?
jaykay11
Yah, it is at @16 1.1 as I type this, till you run a game/benchmark etc.
